OIL LIGHT stays on and blinks
Old Oct 25, 2003 | 04:06 PM
ultra efro's Avatar
Default OIL LIGHT stays on and blinks
Just put a new motor in. I know it has oil in it. Car runs but oil light stays on and then starts blinking? Any ideas?
Old Oct 25, 2003 | 04:30 PM
Kataku2K3's Avatar
Default Re: OIL LIGHT stays on and blinks (ultra efro)
Before you really start driving around I would definately check a few things... First if you have an extra oil pressure sender swap it in and see if it goes away.. If not then check the oil pressure senders wiring all the way back to the gauge cluster (this will save you sometime if you can find the problem there)... Check the light again, if it's still on then it's most likely something mechanical... Does the oil pan have any BIG dents... Especially ones towards the oil pump side (#1)... If so pull the oil pan and check it out, a lot of times these dent makes it hard for oil to be sucked up into the pump and runs your motor really dry (If so it's easiest just to replace the oil pan) The oil pick up could also be plugged up so clean it out... You rarely ever see oil pumps go BAD but sometimes things happen and it could also be that... When I put my friend Mike's (jdmDXrex) B16 (from Hondamotorsonline) into his '88 Rex a couple years ago we had the same problem... A few days after the motor went it he started getting an oil pressure light (it was the dented oil pan smashing the sump)... We pulled the oil pan off and found a mangled thrust washer (It had destroyed the crank and block) It was too late so I just built him a new motor... Anyways, those are the real problems that I see it being... It may be something else but those are the most common... Good Luck
Old Oct 25, 2003 | 04:49 PM
ultra efro's Avatar
thank you. ya for sure dont have no oil pan dents.
Im going to ck oil pressure sensor not installed correctly/damaged
-oil pickup not installed correctly/damaged.
Old Oct 25, 2003 | 05:17 PM
ultra efro's Avatar
Im think its the pickup you tell me when we a started the motor oil pump was leaking a little from it.Its a new oil pump. So i took off and fix the leak But the in the process of doing that i bent the oilpickup up a little enought that it was hard time lining up the holes to bolt back down. U think i mess it up so the light would stay on if the oil pickup was damage?
Old Oct 25, 2003 | 05:36 PM
Kataku2K3's Avatar
Default Re: (ultra efro)
If it's just bent a little I don't really think it would cause that big of a problem but when you think about it, it's something that was messed with and could cause you the problem you have now... I would just pull the pan, double check, and clean everything... Did you put a new oil pump to pick up??? Most of the time you can reuse them even tho I don't... Just check for any big leaks or clogging... Good Luck again...
Old Oct 25, 2003 | 06:01 PM
ultra efro's Avatar
y it was a new oil pump. Do u think i could have put to much SILICONE that could have clog it. But for sure tomm i will change oil pick up i have a extra one.
Mikewallace
Aug 26, 2018 05:53 PM
itzyaboyzeem03
Jul 1, 2016 04:40 PM
slow_low_eddie
Aug 20, 2014 07:04 PM
Donkeeyyy
Jan 3, 2010 12:13 AM
Greg50Lt
Honda Civic (2006 - 2015)
Nov 7, 2009 03:08 AM
