Can't get RC injectors in!!
i bought some rc injectors and i cant get the bastards in.....there 550s and going on a h22...they're also going on a venom rail....can someone help me?
Probably the same issue as with teh B-series manifolds coupled with RC or other Siemens/Delphi injectors. You have to bore out the inside of the injector grommet and plastic washer to get the injectors to seat properly into the intake manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killa_lude »</TD></TR><TR><TD CLASS="quote">the grommets are too large</TD></TR></TABLE>
Are you using the ones that came with the injectors?
I have 550's and they fit fine... Every motor I've built has been fine, send me a picture of what you are talking about and maybee I can better understand what you are talking about.
Sean C.
Sean C.
the injectors dont fit into the mani...when you put the rubber o-rings on the injector they stretch and you cant get the injector in....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killa_lude »</TD></TR><TR><TD CLASS="quote">the injectors dont fit into the mani...when you put the rubber o-rings on the injector they stretch and you cant get the injector in....</TD></TR></TABLE>
LOL On RCs the o-rings don't go on the injectors. They sit on top of them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killa_lude »</TD></TR><TR><TD CLASS="quote">huh....can you clarify that?</TD></TR></TABLE>
It's clearly stated in the directions that came with mine. They call it a cushion. Some of them have a spacer under the grommet that needs to be removed also.
I know what your talking about I have 310's that seemed like they didn't fit what I did was put the injector half way in the o-ring which makes the bottom of the o-ring taper they will then fit into the manifold slightly, then put the fuel rail on a tourque it down they will fit in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik1 »</TD></TR><TR><TD CLASS="quote">I know what your talking about I have 310's that seemed like they didn't fit what I did was put the injector half way in the o-ring which makes the bottom of the o-ring taper they will then fit into the manifold slightly, then put the fuel rail on a tourque it down they will fit in.</TD></TR></TABLE>
were you concerned at all about breaking the fuel rail...i'm actually having the same problems and was hoping to get a different sized rubber grommet from RC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chet »</TD></TR><TR><TD CLASS="quote">
were you concerned at all about breaking the fuel rail...i'm actually having the same problems and was hoping to get a different sized rubber grommet from RC. </TD></TR></TABLE>
I have put the injectors in and out several times without any problems, just make sure that you only put a little bit of touque on each nut then move on to the next one that will prevent it from breaking. I suppose the proper way would be to go and get the proper grommet though.
