low compression, what can it be?
Old Oct 25, 2003 | 09:21 PM
geezer06's Avatar
Default low compression, what can it be?
got 95 gsr..head is milled...about 25 thousanth...new stem seals, retainers, and springs. this is the problem. the car won't start. it'll try to but it wont. did a compression test and cylinder 1 was at 120, and the rest at 140. that is too low! for all i know. could it be the stem seal? need help!
Old Oct 25, 2003 | 09:37 PM
Chiovnidca's Avatar
Default Re: low compression, what can it be? (geezer06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geezer06 &raquo;</TD></TR><TR><TD CLASS="quote">got 95 gsr..head is milled...about 25 thousanth...new stem seals, retainers, and springs. this is the problem. the car won't start. it'll try to but it wont. did a compression test and cylinder 1 was at 120, and the rest at 140. that is too low! for all i know. could it be the stem seal? need help! </TD></TR></TABLE>
Is it getting gas? Is it flooded? Check your compression again after you get the engine warmed up.
Old Oct 25, 2003 | 09:52 PM
geezer06's Avatar
Default Re: low compression, what can it be? (Chiovnidca)
i'm getting fuel and spark...but motor won't start.
Old Oct 25, 2003 | 10:40 PM
mmuller's Avatar
Mad Scientist
those comp. #'s are way low, are you testing with the tb open?have you tried putting a cap of oil in the cylinders to see if compession changes, if not do a leakdown test.
could be a # of things, valve seats, seals, rings
Old Oct 26, 2003 | 04:43 AM
Chiovnidca's Avatar
Default Re: low compression, what can it be? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">those comp. #'s are way low, are you testing with the tb open?have you tried putting a cap of oil in the cylinders to see if compession changes, if not do a leakdown test.
could be a # of things, valve seats, seals, rings</TD></TR></TABLE>
It should still start. Anything over 100 psi is enough to get them started.
95civic007
Mar 26, 2013 03:14 PM
chuisek9
Sep 9, 2007 11:01 PM
-Darren-
May 23, 2006 02:29 PM
blacksihatch
Jun 7, 2005 02:04 PM
