when I turn
Old Oct 24, 2003 | 06:55 PM
JpiZz0's Avatar
Default when I turn
it is not a clicking noise...did a search and all that came up was axels clicking
when i give it a quick jerk or turn all the way it sometimes makes a loud thump or bang.
any ideas? also i hear this annoying squeeking from the front and rear strut towers...you think lube the bushings? ideas on that? and while im posting every time i hit a bump the exhaust makes all this bumping noise in the rear..i replaced all the rubber hangers w/ ones from pep boys but i dont know???suggestions?
any help especially in the turning problem would be greatly appreciated
thanks
jp
Old Oct 25, 2003 | 08:04 AM
RCautoworks's Avatar
Default Re: when I turn (jPs vTec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jPs vTec &raquo;</TD></TR><TR><TD CLASS="quote">it is not a clicking noise...did a search and all that came up was axels clicking
thanks
jp </TD></TR></TABLE>
About the loud bang, are you sure its not the axle ? Put your car in reverse and go around in circles, if its the axles you will hear it. If its not the axles it almost sounds like a bad engine mount. Do you hear this sound any other time ? About the noise, just lube the bushings up and that should take care of it. And the muffler sound, how are you heat shields holding up ? Sounds like they could be a little loose.
Old Oct 25, 2003 | 09:24 PM
JpiZz0's Avatar
Default Re: when I turn (90blackcrx)
crx.....no heat shields on the car except the one on top of the cat. the noise is comming from the rear where the muffler is.
really think its the axles? i was told it might be a tie rod bushing...thoughts on that
but thanks for the input so far
jp
Old Oct 25, 2003 | 09:51 PM
B and B's Avatar
Loved
Community Favorite
The pop could also be dry ball joints
Old Oct 25, 2003 | 10:07 PM
JpiZz0's Avatar
Default Re: when I turn (B and B)
pop?
Old Oct 25, 2003 | 10:33 PM
mmuller's Avatar
Mad Scientist
if it also does it when stopped, it could be your steering rack.
and if not as sayd above it could be balljoints
Old Oct 26, 2003 | 01:20 AM
JpiZz0's Avatar
Default Re: when I turn (mmuller)
cool im going to check the ball joints tommorow...anybody have recomendations on grease?longer lasting?
white lithium, teflon, etc?
thanks again
jp
gurlracer_camille
11
Dec 15, 2006 05:23 PM
sshaikh01
10
May 30, 2003 06:06 AM
shipsaeki
May 28, 2003 07:13 PM
JL 74
Dec 20, 2002 09:08 AM
