Spark Plug #1 Leaner Than The Rest?
Old Oct 24, 2003 | 06:17 AM
SOFLSOL's Avatar
Default Spark Plug #1 Leaner Than The Rest?
Is this common? Even after my dyno time with a little richer than should be A/F mixture I still notice when I check the plugs #1 is a lighter more white/black color than the rest. 2-4 is usually a nicer blackish brown. Is #1 where when the car is turned off the cylinder that stops receiving fuel first?
Old Oct 24, 2003 | 07:50 AM
wickedEFguy's Avatar
Default Re: Spark Plug #1 Leaner Than The Rest? (SOFLSOL)
sounds like you may have an injector slightly clogged. I would have them flow tested and recalibrated. Or you can dump a crap load of injector cleaner and see if that helps
Old Oct 24, 2003 | 08:57 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
this has happend to me also ..and it turned out to be the injector...be carefull using too much injector cleaner too often will ruin "factory" injectors..i learned the hard way
Old Oct 24, 2003 | 09:48 AM
SOFLSOL's Avatar
Default Re: Spark Plug #1 Leaner Than The Rest? (bruceleeroy)
Hrm. Is there anyway I can test this in the motor? I did run injector cleaner on my first tank when these 450's were installed. And also checked them and they all looked to be in great shape. Actually came from a friends talon that swapped them out for more boost.
Old Oct 24, 2003 | 10:10 AM
SOFLSOL's Avatar
it also seems like cyl 4 is richer than 3.. 3 richer than 2.. 1 = leanest.. by the color of the plugs. 4 is always darker and it goes down the line. Could this be because of the screwey endyn fuel pressure relief mod I did? My fuel pressure is like 38 at idle with vac line on. I have a aem fpr to put on so I guess I'll see if it helps at all.
Old Oct 24, 2003 | 04:12 PM
h22 civic's Avatar
its prob cloged injectors take the 1 out the is running lean and swap it with a noter cyclinder and see if it leans out also
Old Oct 24, 2003 | 04:41 PM
poison's Avatar
Default Re: (h22 civic)
I had this exact problem just recenly. My H22 feeds the fuel from cylinder #1 and #4 seems to be running leaner than the other cylinders.
I took off the fuel rail and checked the injectors, and there was a butt load of build up on all of them (particularly #4 injector).
I cleaned everything including the ports where the injectors go in, and I am still checking to see if this fixed the problem -- also I ran fuel injector cleaner (not that it really works much), but nonetheless hopefully fixed the problem.
Try it out and see what happens.
Old Oct 25, 2003 | 05:06 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOFLSOL &raquo;</TD></TR><TR><TD CLASS="quote">Hrm. Is there anyway I can test this in the motor? </TD></TR></TABLE>
Try swapping #1 and #2 injectors to see if the problem changes cylinders.
NevinJoe
Sep 17, 2025 12:50 PM
EG6 Love
Sep 24, 2013 09:11 AM
rock2447
Feb 10, 2003 12:59 PM
Kamin
Aug 3, 2002 12:08 PM
JSpecwest
Jan 4, 2002 01:23 PM
