Help! swap problems
Old Oct 26, 2003 | 06:35 AM
bluegen2's Avatar
Default Help! swap problems
ok well i took out my ls/vtec setup and installed the jdm b16(xsi) swap in my car...everything is done...but the car wont start...tries to turn over but isnt gettin any spark....please help...any lil bit is appreciated.
Old Oct 26, 2003 | 07:23 AM
bluegen2's Avatar
c'mon i know someone on this board can help me...
Old Oct 26, 2003 | 08:54 AM
civicrtype's Avatar
Default Re: Help! swap problems (bluegen2)
are u getting fuel? do u hear the fuel pump priming when u put the key in the ON position? If not check your grounds especially the ground on your Thermostat housing, if this is loose it will cause your main relay not to work and you wont get spark or fuel.
Old Oct 26, 2003 | 01:05 PM
sohc it to me's Avatar
Default Re: Help! swap problems (civicrtype)
make sure ur spark plug wires are in the right order
DSK 86CRX
Feb 1, 2007 02:01 PM
civicgeek133
Jun 6, 2005 04:03 AM
temp
15
Jul 6, 2004 08:07 PM
2ndGenREX
Dec 3, 2003 07:11 PM
[626]95-GSR
30
Feb 16, 2002 12:06 PM
