What is wrong with my car!!??
Old Oct 22, 2003 | 12:28 PM
xerox445's Avatar
Default What is wrong with my car!!??
I have been having clutch problems...
https://honda-tech.com/zerothread?id=651022
That should explain it all...but for some reason i dont think its the clutch, i still only get a very soft, dead pedal when the car is runnin...what could be causing this? I just got a new clutch master cylender and its no different, the pedal is sometimes getting stuck to the ground...but its very stiff and good when the car is off...whats the deal? Is it my throwout bearing or just some hydrolics...it has a new slave cylender, and a new master cylender...whats the deal. I NEED HELP, i dont have to have to put a new clutch in if i dont have to. Btw, the clutch i have now is a exedy unit (dont know stage) with the pressure plate and new bearings...(i assume)...(and hope) Please help me!!!
Old Oct 22, 2003 | 01:44 PM
xerox445's Avatar
Default Re: What is wrong with my car!!?? (xerox445)
bump, i seriously need help, I just bled it again and i got like NO air in the line...whats going on? What could cause the clutch not to disengage, and get a totally limp pedal, just when the car is turned on? Is there like a vacume assist or something? Btw, its a CX 95 EG...with 98 gsr swap, as far as i know its the CX masters...., help?
Old Oct 22, 2003 | 03:21 PM
xerox445's Avatar
bump please help?
Old Oct 22, 2003 | 04:06 PM
Discosteak's Avatar
i would check the throwout bearing if the pedal is getting stuck you may have a bad throwout i think
Old Oct 22, 2003 | 06:08 PM
xerox445's Avatar
Default Re: What is wrong with my car!!?? (BADEG6)
hopefully thats it, how can u tell if there acually trans damage when doing a new clutch job?
Old Oct 22, 2003 | 06:47 PM
xerox445's Avatar
bump
Old Oct 22, 2003 | 06:52 PM
mmuller's Avatar
Mad Scientist
im assuming that you checked that master and slave cylinders are ok right?
when you press on the clutch, is the slave cyl. moving all the way, when you hold the clutch down does the slave stay put or it looses pressure after a bit?
as far as the noise, does it do it at idle?when you press the clutch goes away?kinda like a helicopter?
could be release bearing
Old Oct 23, 2003 | 08:03 AM
xerox445's Avatar
yeah the slave still moves the arm even when it gets really soft...im hoping its just the clutch, and im can just replace that, and drive my car normally
jfirusta
Honda CR-V & Element
Dec 17, 2020 06:04 PM
Youshady2
Oct 21, 2013 01:54 PM
LL2009
Sep 3, 2005 11:55 PM
jerBEAR
Aug 14, 2005 11:18 PM
DriveSideWays
Mar 3, 2004 06:16 AM
