Axel problems
Old Oct 23, 2003 | 05:36 AM
Fr0mh311's Avatar
Default Axel problems
My friends was trying to replace in axel and ended up messing it up now he's asked me for help but I'm not sure what to do. He removed the old axel no problems but he rushed putting the new one in and did both to match it up to the old one. well it turns out it's the wrong axel that where the problem comes in he can't get it back out the thing it bound in there. Does anyone have any suggestions? Thanks
Old Oct 23, 2003 | 06:25 AM
BeerMan's Avatar
Default Re: Axel problems (Fr0mh311)
How is it bound in there? Use a crowbar and/or hammer. Pry, tap, hammer, jiggle, yank.
Old Oct 23, 2003 | 06:38 AM
Toxidomask's Avatar
dont they make a special puller? a slide hammer type? check out autozone, ask them what other tools they have besides the pry bar; I believe they might have it.
Old Oct 23, 2003 | 06:56 AM
wickedEFguy's Avatar
Default Re: Axel problems (Toxidomask)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toxidomask &raquo;</TD></TR><TR><TD CLASS="quote">dont they make a special puller? a slide hammer type? check out autozone, ask them what other tools they have besides the pry bar; I believe they might have it.</TD></TR></TABLE>
even if they did it would be a wate of money, Using a crow bar or pickle fork would be cheap and effective if your carefu. Well at least that's how I always take my axelsl
Old Oct 23, 2003 | 08:22 AM
Toxidomask's Avatar
Default Re: Axel problems (Ninja_Jc7)
They rent the tools free, I forgot to mention that. sowee
Old Oct 23, 2003 | 04:08 PM
Fr0mh311's Avatar
tried for 2 to 3 hours with both a pickle fork and pry bars. That thing is in there good. it also makes a clicking noise when he drove the car to test it. The wheel is also wobbly. I replaced the bearing to try and fix that but it didn't help. I think he messed it up good. He should have waited for me to help him as he likes to rush things.
Old Oct 24, 2003 | 05:32 AM
Fr0mh311's Avatar
To The Top
Old Oct 24, 2003 | 01:26 PM
Fr0mh311's Avatar
And Again
Old Oct 25, 2003 | 06:31 AM
Fr0mh311's Avatar
Bump
Old Oct 25, 2003 | 08:18 AM
Big Teggie's Avatar
Just use a screwdriver like this
Picture taken by B18c5-Eh2
Old Oct 25, 2003 | 10:02 AM
keithg's Avatar
If your friend is lucky enough to have a limited slip differential, you can remove the axle from the opposite side and drive out the stuck axle with a long punch and big hammer. This will only work on trans with lsd as there is a hole through the center of the differential allowing you to do this. It seems to me the the lsd trannys have a tendency to have this problem of the axle getting stuck more often than the non-lsd trannys.
Old Oct 25, 2003 | 12:50 PM
goapele's Avatar
Default Re: Axel problems (Big Teggie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Teggie &raquo;</TD></TR><TR><TD CLASS="quote">Just use a screwdriver like this
Old Oct 26, 2003 | 06:50 AM
Fr0mh311's Avatar
Default Re: Axel problems (goapele)
that's exactly what we were doing but it's not budging.
HCJDM1
33
Feb 5, 2007 05:50 PM
BigDawwg6969
10
Aug 15, 2005 06:12 PM
91_civicsi
20
Apr 12, 2005 06:05 PM
mhgleitz
Aug 20, 2004 02:15 PM
Just Checking In
Apr 27, 2003 07:52 PM
