gsr and ITR parts
Old Oct 25, 2003 | 02:44 PM
gsrinstyle's Avatar
Default gsr and ITR parts
i have a 00 gsr. im getting skunk 2 IM, apexi vafc, aem cam gears, and now im thinking of getting ITR cams off an 2001. is it worth it? or should i spend some more money on different cams??
basically, what cams should i use?? i dont intend to change valve springs or retainers.
Old Oct 25, 2003 | 04:05 PM
Kataku2K3's Avatar
Default Re: gsr and ITR parts (gsrinstyle)
If you're aren't really doing any big internal work (i.e. higher compression, headlwork, etc.) don't waste your money with aftermarket cams... I would recommend a CTR/2000+ ITR (same) IN cam and don't even worry about the exhaust... There isn't a big difference at all but if you want it anyway then get it... Good Luck
Old Oct 26, 2003 | 10:03 AM
Hankish's Avatar
Default Re: gsr and ITR parts (Kataku2K3)
Get a good used CTR intake cam. I got mine on HT for $130 shipped. Then start saving for some bigger cams and higher compression. You will be hooked on the power sooner than you will be able to think!
Then take REAL advantage of that GSR
Old Oct 26, 2003 | 05:42 PM
gsrinstyle's Avatar
Default Re: gsr and ITR parts (Hankish)
so, i could simply buy the ITR intake cam, and just install that?? im from canada and i dont know where i could find the CTR intake cam.
whats the difference between ITR cams and skunk2 stage 1 cams??
is it worth just going for the stage 1 cams from skunk2?
how would i put my compression up?
Old Oct 26, 2003 | 05:46 PM
hybridEj6's Avatar
Hmotorsonline.com sells ctr intake cams. i have a jdm b18c with a ctr intake cam and im very happy with it, i dynod 179.4hp with 130tq im still using the stock gsr (sir-g) exhaust cam and am using stock valve train.
Old Oct 26, 2003 | 05:58 PM
gsrinstyle's Avatar
Default Re: gsr and ITR parts (ekhybrd)
but the 00-01 ITR cams are the same as CTR cams right?
Old Oct 26, 2003 | 06:21 PM
hybridEj6's Avatar
there is a little more duation on a ctr intake cam
Old Oct 26, 2003 | 06:38 PM
Kataku2K3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekhybrd &raquo;</TD></TR><TR><TD CLASS="quote">there is a little more duation on a ctr intake cam </TD></TR></TABLE>
Have you degreed a CTR cam over an ITR before?? Trust me, you won't notice a difference so they are pretty much identical... As for the SK2's I really wouldn't waste my money... Bigger more aggressive cams don't do anything for a STOCK motor... Like I said if you really want more power, build the bottom end with higher compression pistons (OEM, JDM GSR/P72-00, USDM ITR/P73-A0, JDM ITR/P73-00, PR3, P30, CTR/PCT) are all OE pistons that will yield a higher compression ratio in your motor... Search around and you'll hear a lot... For all motor purposes you'll also find out that headwork and cam selection determine everything... Don't get a BIG cams right now, you'll just lose hp and be slower... Also search around online, if you don't have any places locally there are a lot online that sell JDM R parts... Unless you're looking at building your motor I would just stick to OEM parts... Just my $0.02... Good Luck
Old Oct 26, 2003 | 06:59 PM
hybridEj6's Avatar
yes katsuka you are right the difference is so little that you wouldnt notice the difference
Old Oct 26, 2003 | 07:25 PM
gsrinstyle's Avatar
thanx alot man. so, i could just install the ITR intake cam, right?
Old Oct 26, 2003 | 11:15 PM
Kataku2K3's Avatar
Yup, it's as easy as that...
Old Oct 26, 2003 | 11:19 PM
NA gs-R 05 C
Guest
Posts: n/a
if you're not planning to change your valvetraing, itr cams is a very worthy mod, along with skunk stage 1's.
Old Oct 26, 2003 | 11:26 PM
Formula 1's Avatar
Default Re: gsr and ITR parts (NA gs-R 05 C)
kinda depends on your plans for the car ...then you can choose what kind of parts u should buy
Mike K
Feb 13, 2007 10:54 PM
G-Phi
Apr 16, 2006 01:14 AM
Vtecme92
Oct 15, 2005 07:53 PM
turbo gsr
Oct 5, 2005 01:26 PM
wdyno
Jul 21, 2001 12:56 AM
