bad cyl position sensor?
Old Oct 22, 2003 | 10:17 AM
liquid51's Avatar
Default bad cyl position sensor?
Can a bad sensor, be it cylinder position, tdc, or crank position, cause the engine to have a bouncy idle? Could it also be the cause for not being able to give in any gas when in gear (wants to die under ANY load)? Or would it not run at all?
Please help me out here if you can. I've been trying to get this thing to run correctly for 3 months now and I'm getting pretty depressed about it. I'm about ready to set it on fire.
Old Oct 23, 2003 | 04:53 AM
EE_Chris's Avatar
Default Re: bad cyl position sensor? (liquid51)
CEL on?
Old Oct 23, 2003 | 05:00 AM
rsbad454's Avatar
Default Re: bad cyl position sensor? (EE_Chris)
what do you mean bouncy? if the idle is going up and down its more than likely the IACV........check ECU for codes.
Old Oct 28, 2003 | 11:53 AM
liquid51's Avatar
Default Re: bad cyl position sensor? (rsbad454)
yes, bouncy meaning fluctuating by a few hundred rpm, up and down.
The reason I asked is because Tom Payne at payne tech diagnosed my problem for me and said the idle problem might be cause by a bad ckp sensor, in turn causing the IAC valve to act up. It doesn't make sense to me, but the guy is supposed to know what he's talking about (if you know anything about the new crate motors about to go on sale, you can thank dart and Tom Payn. so the guy knows his stuff, but I'm a bit confused).
higgunscrx
Apr 15, 2008 12:28 PM
fadedgsr
Apr 5, 2008 03:30 AM
kootari
Feb 10, 2007 04:07 PM
90prelude2.0Si
Oct 13, 2005 12:48 PM
x00gsr
Nov 10, 2004 08:53 PM
