HOW TO REMOVE AND INSTALL ROTORS???
Old Dec 11, 2003 | 03:46 PM
VWTECH1's Avatar
Default HOW TO REMOVE AND INSTALL ROTORS???
YO.HAVING TROUBLE..SOMEONE HIT ME BACK!
Old Dec 11, 2003 | 03:49 PM
mastarolla's Avatar
Default Re: HOW TO REMOVE AND INSTALL ROTORS??? (VWTECH1)
what vehicle are you working on first....
Old Dec 11, 2003 | 03:50 PM
ExiledinIN's Avatar
What's the problem? Is it the two screws that hold the rotors onto the hub? If so, use an impact driver:
http://www.sears.com/sr/javasr...CRAFT
Spray some penetrating fluid on it and wait. Then use the impact driver.
Need to take the calipers off first and then the rotor (e brake cable on the rear if you have calipers in the rear).
BTW, what car are you working on?
Old Dec 11, 2003 | 03:59 PM
benSC's Avatar
Just drill the little bastards out. You don't really need them anyway.
Old Dec 11, 2003 | 04:01 PM
mastarolla's Avatar
Default Re: (benSC)
haha something about honda using them for the assembly line so the rotor stays on the hub.....
Old Dec 12, 2003 | 04:46 AM
JimBlake's Avatar
Default Re: (mastarolla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mastarolla &raquo;</TD></TR><TR><TD CLASS="quote">what vehicle are you working on first....</TD></TR></TABLE>Some years Accords have pressed-on rotors. If he's talking about one of those, all this BS about the rotor screws isn't gonna help him...
Old Dec 12, 2003 | 01:04 PM
dwolsten's Avatar
I don't know if this actually works or not because I haven't tried it, but one idea I've heard is to put the lugnuts (or appropriately threaded open hex nuts) back onto the studs after removing the wheel, then torque them down some (evenly). This should take pressure off the screws, making it easier to get them off. YMMV.
Old Dec 12, 2003 | 04:23 PM
si autoxer's Avatar
Default Re: HOW TO REMOVE AND INSTALL ROTORS??? (dwolsten)
Never thought about ever doing that but it sounds like a good idea.
Old Dec 14, 2003 | 02:46 PM
vtekstorm's Avatar
Default Re: HOW TO REMOVE AND INSTALL ROTORS??? (si autoxer)
impact driver works but u gotta be carful u dont break the bit on the driver another way is to take a center bunch or a small chizel with a narrow point and tap the screw out ive done it a few times and it works
Old Dec 14, 2003 | 02:54 PM
LudeyKrus's Avatar
what exactly are ya'll talking about, the piece that is there from the factory and can be drilled out? got any pics?
JDMproblem
17
Apr 6, 2007 04:26 PM
Anthrolude
Apr 6, 2005 06:57 AM
fso_BamBam
Jul 1, 2004 01:08 PM
es_squared
Jun 17, 2004 04:18 PM
navin
Nov 11, 2003 02:28 PM
