my car is hesitating (not all the time though) HELP
Old Dec 18, 2003 | 02:07 AM
ndogg's Avatar
Default my car is hesitating (not all the time though) HELP
been doing this for about a month now. it usually happens when i am at light throttle. around 2-4K rpm, on the freeway mostly. it only happens a few times a day. it will start to studder, if i give it more gas, it starts popping really loud and i usually let off. sometimes i will stay on the throttle it will continue missing and sometimes it will not. when it starts and then i let up right away, about half the time it will studder again when i give it gas again, the other half, it will be ok. this has never happened to me during WOT. i have replaced:
cap/rotor
plugs
wires
fuel filter
fuel pump
checked ignition timing
checked cam timing
and i am halfway through a tank of injector cleaner.
problem still persists. now today, i threw a code on my way home and i was all excited that this could lead me to a solution. damn code 1 (o2). so i'm kinda stumped for things to do now. injectors? o2? map?
PLEASE HELP ME
i just reset the ecu and went for a drive, the code never came back on.
Modified by ndogg at 3:30 AM 12/18/2003
Modified by ndogg at 3:32 AM 12/18/2003
Old Dec 18, 2003 | 03:40 AM
MiraiZ's Avatar
Default Re: my car is hesitating (not all the time though) HELP (ndogg)
Answered your own question...bad O2 sensor causing you to run rich...
Old Dec 18, 2003 | 04:52 AM
ndogg's Avatar
Default Re: my car is hesitating (MiraiZ)
hopefully you're right. i just disconnected my o2 signal wire (open loop) and went for a 20min drive on the freeway and it never fu**ed up. but like i said, it only happens occasionally so only time will tell. pray to the honda gods for me
Old Dec 18, 2003 | 05:22 AM
90'JDMteg's Avatar
Default Re: my car is hesitating (ndogg)
my ls did that sometimes and it was the spark plugs.
Old Dec 18, 2003 | 11:41 AM
Don Napier's Avatar
Import Alliance
Default Re: my car is hesitating (90'JDMteg)
probably is the o2.
killa69er
Feb 28, 2011 08:56 PM
flipldls
29
Jul 12, 2010 06:05 PM
slowcrxsib16
Dec 20, 2008 09:32 AM
louevilhatch
Jun 27, 2007 11:43 PM
flat-blk-HB
Apr 5, 2002 04:30 PM
