Need Help on wiring - 5" AUTOMETER Tachometer in B16A
anybody here can teach me how to install an 5" AUTOMETER Tachometer in 96 civic pillar panel. how can i do the wirings, especially wiring to the distributor. my engine is B16A1 from civic year 92, P30 ECU.
any picture for the installation please. Thanks.
There is a power, a ground, an illumination light that you connect to your dimmer switch, and an ignition output signal wire that connects to the thin blue wire coming from your distributor. You can trace that through the harness and splice it off the ECU pin, or you can run the wire through to the engine bay and splice it in at the distrib.
https://honda-tech.com/zerothread?id=502212
sorry pal. ur info is great, but i can't see the picture. could you send it to my e-mail, acidburns_di@yahoo.com thanks.
http://www.autometer.com/hp/in...j.pdf
OR
run the green wire to the blue wire on the large engine harness plug closest to the driver's side.
OR
thanks for your concern man. but i do have all that info from AUTOMETER websites already. so, now i'm just not sure about those;-
1) should i disconnect my battery before do any wiring? what kind of fuse? any picture?
2) can i use 10amp fuse for red wire which is connect to 12v ignition switch? ( it should be 4amp according to AUTOMETER ).
better for me to ask this stupid quesstion first before i make the stupid mistakes later on.
Thanks.
Thanks.
Girlzcn2
Dec 22, 2003 04:34 AM
autometer, b16, b16a, blue, distributor, honda, ignition, install, installation, malaysia, signal, tach, tachometer, wire, wiring
