helpp....cel stays on when checking codes
Old Dec 16, 2003 | 10:03 AM
denshu's Avatar
Default helpp....cel stays on when checking codes
hello all
i had a cel come on before for the o2 censor...and then changed it o2....when i went to check the cel codes again....the cel stays on when i jump it...
is that normal? or do i have a bad ecu?
i have a chiped ecu with itr program
p30
odb1
can anyone help out?
thankssssssssss
Old Dec 16, 2003 | 10:31 AM
mattssi's Avatar
My friend had the same problem, I think that you have the paper clip, wire, in wrong! Tske it out and then put it back in! It has to be touchng the two metal pins!
Old Dec 16, 2003 | 01:48 PM
96dxB16's Avatar
Default Re: helpp....cel stays on when checking codes (denshu)
from what i've heard solid cel while jumping means bad ecu. are you sure you're jumping it correctly? maybe it wasn't in all the way?
Old Dec 16, 2003 | 01:53 PM
AzG35's Avatar
Default Re: helpp....cel stays on when checking codes (96dxB16)
Did the CEL come back on or are you just trying to see if there are any codes again? If you jump the ECU without the CEL ever being thrown, the light will stay solid because there are no codes. If it did throw a CEL, and the light is solid, it usually means the ECU is bad.
Old Dec 16, 2003 | 02:08 PM
denshu's Avatar
Default Re: helpp....cel stays on when checking codes (AzSi22)
thanks for the replies
yes i'm trying to see if the o2 code was still there....but it gave me a soild light.
no cel came on after i changed the o2 sensor.
so does this mean i have no codes? i thought no codes was no soild light when jumping?
Old Dec 16, 2003 | 02:21 PM
PHiZ's Avatar
I believe you get a solid CEL when you have no codes, correct. So if you have no CEL, when un-jumpered, and then you jumper it, and it's solid, it means no codes.
If you have a CEL, and jumper it, and it is still a solid CEL, that means bad ecu/ecu program.
-PHiZ
Old Dec 16, 2003 | 02:48 PM
denshu's Avatar
Default Re: helpp....cel stays on when checking codes (PHiZ)
thanks alot everyone!!!!
radicaled434
Feb 23, 2013 06:45 PM
s13hero
Nov 13, 2011 05:16 PM
japek
Mar 19, 2010 08:34 PM
honda4674
Mar 30, 2006 07:20 AM
h8tred
Jul 7, 2003 08:35 PM
