CAR WONT START! HELP
Old Dec 16, 2003 | 01:25 PM
-[95cxhatch]-'s Avatar
Default CAR WONT START! HELP
Ok here is how this situation all started. I'm driving home from work in 3rd gear at about 2500 rpms then bam my engine just shuts off. I figured it was the timing belt or fuel pump. I inspected the timing belt and its not broken, I couldnt hear the fuel pump turn on when i turned the key to the on position so I went on further by unhooking hte fuel line that ran into the filter and tried to start the car and see if fuel was coming out. No fuel was coming out so it has to be the fuel pump right? nope. I just replaced the fuel pumpi can hear it come on and now fuel is coming from the fuel line that runs into the filter. Still no start. I replaced the main relay in may so I dont think it can be that. if anyone has any suggestions I would greatly appreciate them. My engine is a d16z6 (p28 ecu not chipped) my mods are just a header and intake the car is a 92 lx sedan
thanks in advance
Old Dec 16, 2003 | 01:29 PM
b20turbojason's Avatar
Default Re: CAR WONT START! HELP (92lxsedan)
check to see if you are getting spark
Old Dec 16, 2003 | 01:30 PM
Default Re: CAR WONT START! HELP (b20turbojason)
how? i took a spark plug out hooked it up to my wire then layed it on my header...hoping to ground it but it didnt sprk but i dont think myheader is a good ground
Old Dec 16, 2003 | 01:41 PM
93civicEX's Avatar
bad coil
Old Dec 16, 2003 | 02:09 PM
8200RPM's Avatar
local hippie
Default Re: (93civicEX)
yea check your coil cause the same thing happened to me a few months back.... i was at a light, put it in gear and took off...then...my car just died. I had to replace the coil
Old Dec 16, 2003 | 03:32 PM
Jimmy's Avatar
Global Moderator
happened to me and it was my ignitor.
Old Dec 16, 2003 | 05:18 PM
no spark now i tested the coil and it checked out ok
dre33333
Dec 2, 2020 07:24 AM
H22TurboNos
Nov 5, 2007 03:16 AM
diewX3
Jan 11, 2005 11:50 AM
crxxrc
Feb 8, 2004 01:39 PM
-[95cxhatch]-
Dec 16, 2003 05:20 PM
