D16Z6 in a 4G Prelude
Old Dec 16, 2003 | 02:14 PM
jbell's Avatar
Default D16Z6 in a 4G Prelude
i wanna do a turbo setup in a prelude...
what are the possibilites of swapping in a d16?
is there an easier way to make power cheaper?
i know the prelude blocks cant hold boost very well so i thought this would be a good alternative...
Old Dec 16, 2003 | 02:38 PM
Honda Sport's Avatar
Default Re: D16Z6 in a 4G Prelude (jbell)
are you serious? why would you want to decrease your displacement? especially into a heavier car. you need tq to pull the car which a 1.6L d16z6 has barely any. You would probably end up spending more money swapping the motor then builing up the motor. might as well build the h-series.
Old Dec 16, 2003 | 04:35 PM
EJ1_519
Guest
Posts: n/a
Swap in a H-motor. It's not work downgrading your car to a small d16z6. Why not consider putting in a H22/H23????
Old Dec 16, 2003 | 04:40 PM
Kendall's Avatar
Default Re: D16Z6 in a 4G Prelude (EJ1_519)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1_519 &raquo;</TD></TR><TR><TD CLASS="quote">Swap in a H-motor. It's not work downgrading your car to a small d16z6. Why not consider putting in a H22/H23????</TD></TR></TABLE>
I agree, there is no practical purpose of putting a d series engine in a prelude. Especially a 4th gen which comes standard with the H series. If you have an H23, then consider an H22 swap, or the "H22 head on an H23 block" hybrid.
Old Dec 16, 2003 | 06:20 PM
RyanEJ8's Avatar
Default Re: D16Z6 in a 4G Prelude (dc231)
I am a D series fan myself, and I still agree with these guys. If you already have a bigger displacement motor don't swap it out.
Old Dec 16, 2003 | 07:58 PM
doublejz's Avatar
Default Re: D16Z6 in a 4G Prelude (RyanCivic2000)
z6
Old Dec 17, 2003 | 07:27 PM
jbell's Avatar
to build a h22 (thats stock in the 4g, right?) for boost and turbo it, what does it generally cost?
Old Dec 18, 2003 | 08:32 AM
LudeyKrus's Avatar
4g Prelude has the F22, H23 and H22. All of them make for good boost-engines.
A full build on an H22 will usually run about 3-4k.
TheBaron
Mar 23, 2003 07:21 PM
