quik valve ?
Old Dec 14, 2003 | 05:20 PM
dfoxengr's Avatar
Default quik valve ?
ITR intake valves fit perfectly in b16 head with SK2 VS and retainers? simple swap out
and the exhaust valves are the exact same in both heads correct?
Old Dec 14, 2003 | 07:15 PM
mastarolla's Avatar
Default Re: quik valve ? (hybridvteceg)
call honda and ask to find out the diameter of the in. and exh. valves for the B16 and call acura to ask the same thing for the ITR valves. I believe you might need to get the valves machined a bit to get them to seat but i could be wrong .....
Old Dec 14, 2003 | 07:45 PM
dfoxengr's Avatar
Default Re: quik valve ? (mastarolla)
thought they used the same valve guides.
Old Dec 14, 2003 | 09:25 PM
ProdriveWRC's Avatar
Yes they will fit. The B16 and B18 use the same head.
Alin
Old Dec 14, 2003 | 09:30 PM
dfoxengr's Avatar
Default Re: quik valve ? (ProdriveWRC)
i know that, just wondering if the seats etc were different.
Old Dec 15, 2003 | 03:37 PM
dfoxengr's Avatar
Old Dec 15, 2003 | 03:45 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProdriveWRC &raquo;</TD></TR><TR><TD CLASS="quote">Yes they will fit. The B16 and B18 use the same head.</TD></TR></TABLE>
Not necessarily true, but in the case of the B16A and the ITR head, yes they are from the same casting but the ITR came slightly ported and had a better valve job.
As for the question. Both heads are a PR3 casting so everything between the two is interchangable.
Old Dec 15, 2003 | 03:49 PM
dfoxengr's Avatar
Default Re: quik valve ? (dc231)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc231 &raquo;</TD></TR><TR><TD CLASS="quote">
As for the question. Both heads are a PR3 casting so everything between the two is interchangable.</TD></TR></TABLE>
ok thats what i thought.
PR8urVtec
Oct 3, 2013 04:02 PM
ferio-ichi3
Sep 19, 2013 08:31 PM
bluegdx16
Feb 17, 2005 06:59 PM
2 0 3
Mar 31, 2003 01:33 PM
coasterlvr
Sep 11, 2001 08:11 AM
