block still safe without sleeving?
Old Dec 11, 2003 | 08:55 PM
im_poor's Avatar
Default block still safe without sleeving?
I guess this block has been running water with no coolant and has corroded the outside rim of the sleeve. Anybody know if this block needs to be resleeved?
Modified by im_poor at 12:08 AM 12/14/2003
Modified by im_poor at 11:39 PM 2/4/2004
Old Dec 12, 2003 | 05:26 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: block still safe without sleeving? (im_poor)
oh damn, at first i looked and said a machine shop can clean it up but then looked again and is it me or are chunks of the sleeves missing? if so, you can opt to resleeve but if you're not planning on doing anything with it, ie high comp or forced ind, then just invest in a bare block.
Old Dec 12, 2003 | 05:48 AM
wade's Avatar
OMFG HOUSTON, throw it in the ohio river and find a diff block, right now, the sleeves are fucked even where they mate at between cylinders
Old Dec 12, 2003 | 08:29 AM
9200RPM's Avatar
Thats what happens when you run just water??!??!!? You sure thats the only reason why is looks like that.....All summer I ran just water...You got me scared....
Old Dec 12, 2003 | 12:15 PM
Kendall's Avatar
Find a new block and use this one as an example of what not to do.
Old Dec 13, 2003 | 05:25 PM
9200RPM's Avatar
Default Re: (dc231)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc231 &raquo;</TD></TR><TR><TD CLASS="quote">Find a new block and use this one as an example of what not to do.</TD></TR></TABLE>
was that directed at me???
Old Dec 13, 2003 | 05:38 PM
Kendall's Avatar
No.
Old Dec 13, 2003 | 11:10 PM
im_poor's Avatar
Default Re: block still safe without sleeving? (TurboB16aEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB16aEG &raquo;</TD></TR><TR><TD CLASS="quote">Thats what happens when you run just water??!??!!? You sure thats the only reason why is looks like that.....All summer I ran just water...You got me scared....</TD></TR></TABLE>
well im not sure what else it could have been, poor maintenace? when the coolant was flushed it was just water.
Old Dec 14, 2003 | 07:20 AM
Kendall's Avatar
Yes it was water, and you will need to have the block sleeved if you ever want to safely run it again.
Old Dec 14, 2003 | 08:17 AM
hotintegranights's Avatar
Default Re: (dc231)
just find a bare block usually 150 or less and switch over everything from your old block to the bare one. or you can sleeve it which will be best but also $$$
Old Dec 14, 2003 | 08:19 AM
Kendall's Avatar
Or better yet, get an RS machine block and when it gets to you, send the messed up one back for the core.
IndySporty
Jan 27, 2007 07:36 PM
sodacan33
May 2, 2004 05:53 PM
Slimm-rw-
Apr 6, 2004 01:50 PM
jspeedy
Mar 18, 2004 06:49 PM
4doorH22
Mar 9, 2003 01:26 AM
