where to connect a multimeter to act as a tachometer?
Old Dec 18, 2003 | 12:23 PM
gregv's Avatar
Default where to connect a multimeter to act as a tachometer?
hello
In the search to get my idle set correctly, I would like to use my (cheapo) multimeter as
a tachometer, as the dash one does not seem too accurate at lower revs. Where would I connect
the multimeter to, or is this even possible? The set-up is a DOHC ZC in a '91 Civic Si.
any info appreciated
greg v
Old Dec 18, 2003 | 12:32 PM
Perfectionist's Avatar
Default Re: where to connect a multimeter to act as a tachometer? (gregv)
Well, the meter could see the pulses as an AC voltage. The problem is how to interpolate that reading into actual RPMs.
Old Dec 18, 2003 | 01:43 PM
gregv's Avatar
Default Re: where to connect a multimeter to act as a tachometer? (Perfectionist)
I was thinking more along the lines of using the meter's frequency reading function; do these engines have a mag. pickup somewhere? Or perhaps tapping into the cam postion sensor?
Old Dec 18, 2003 | 04:23 PM
the DR.'s Avatar
my multimeter has an adapter with a clamp that goes around a spark plug wire, and it'll give a RPM readout.
Old Dec 19, 2003 | 03:25 PM
on2wheels's Avatar
Default Re: where to connect a multimeter to act as a tachometer? (the DR.)
I connect one lead to the blue wire on the 2 pin connector that goes to the distributor. This blue wire goes to the dash tachometer. I use a backpinning probe to poke into the back of the connector so that I do not have to pierce any wire insulation. The other lead of course goes to ground. My multimeter has a tach on it but a frequency counter should work fine with a little math.
Old Dec 19, 2003 | 07:45 PM
miller's Avatar
Default Re: where to connect a multimeter to act as a tachometer? (on2wheels)
what kind of multimeters are you guys using?? im looking to buy a good one at the moment and want to get something really good..
Old Dec 19, 2003 | 08:54 PM
b19coupe's Avatar
Default Re: where to connect a multimeter to act as a tachometer? (miller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">what kind of multimeters are you guys using?? im looking to buy a good one at the moment and want to get something really good..</TD></TR></TABLE>
Fluke
averyvm
Jul 15, 2008 07:34 PM
Mugen23cc
Nov 4, 2006 07:42 AM
pnltnc
Apr 17, 2004 10:04 AM
Gonzo_SiR
Oct 29, 2003 10:12 PM
yodude
Jul 13, 2002 02:52 AM
