Loud humming from passenger side? Need help!
Old Dec 17, 2003 | 12:09 PM
92BlackSi's Avatar
Default Loud humming from passenger side? Need help!
Not for My Civic but for a 94 Caravan. I was hearing some grinding for the last little while from the passenger side front. Sounded just like a bad wheel bearing so I got a new hub assembly adn still there HOWEVER...
When turning and OFF gas no noise
When turning and ON gas major noise.
It is not a bad tire.
Any thoughts??
Old Dec 17, 2003 | 12:21 PM
Burke's Avatar
Banned
Default Re: Loud humming from passenger side? Need help! (92BlackSi)
could it be the cv joint???? did all your ball joints, etc look ok
and its fine when in a straight line.
im thinking the axle
good luck!
Old Dec 17, 2003 | 12:56 PM
92BlackSi's Avatar
I don't hear a clicking at full lock which tells me the CV joint. I am thinking the axles as well. The axle seals were recently done, maybe a shitty put together?
Old Dec 17, 2003 | 04:15 PM
DEVIN22CBR's Avatar
Default Re: (92BlackSi)
Wheel bearing.
EDIT: Used junk yard Hub or NEW!? If not that check your ball joints and axles.
Old Dec 17, 2003 | 07:28 PM
Mohudsolo's Avatar
Default Re: (Sac)
On my brother's Caravan it was the outer CV joint. It was tight, not loose and rattly like they usually get. When we pulled it out we found the outer joint was really tight. No damage to the boot but it acted like it was dry for a while. The replacement one did it again about 50K later.
Old Dec 17, 2003 | 08:13 PM
92BlackSi's Avatar
New bearing - used is ***
Wheel bearing is part of the hub for the caravan.
it has to be axles or CV.
Mohudsolo - So the CV was tight and all but had no grease? OR just sounded that way?
Old Dec 20, 2003 | 05:49 AM
hondamanwill's Avatar
Girlfriend?????
TunerShark
25
Nov 4, 2006 03:30 PM
WhiteOnRice
14
Sep 26, 2006 10:16 AM
yaced
15
Apr 5, 2006 10:02 AM
rice_classic
Dec 11, 2004 05:15 AM
Spry
11
Jun 8, 2004 08:33 PM
