All 90-93 LS trannies the same?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverCIVIC96 »</TD></TR><TR><TD CLASS="quote">is there a difference between the 90-91 vs. 92-93 LS integra transmissions?</TD></TR></TABLE>
yes there is.
Internally the 92-93 tranny's are better (imo) because they (1) they're updated technology and (2) they use hydro tranny internals, yet their in a cable casing.
yes there is.
92-93 LS are hydro?
I have a 92 gsr tranny and its cable...
reason I ask is because Im looking for a ls 5th gear that'll fit my tranny.
No the 92-93 LS trannies are not hydro, they just have the same internals as the hydro trannies. It's still a cable tranny, just with updated internals. And the 92-93 GSR trannies are different still. They had different gear ratios but I can't remember if there was a difference in final drive or the way the synchros were set up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverCIVIC96 »</TD></TR><TR><TD CLASS="quote">so does that mean 90-91 LS 5th won't fit my 92-93 gsr tranny?</TD></TR></TABLE>
thats an affirmative.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LBR92DA-T »</TD></TR><TR><TD CLASS="quote">s1 and a1 i believe are 90-91 trannies</TD></TR></TABLE>
i just bought an s1 from the yard out of a 92 ls teg! and now im second guessing what i have!
someone please tell me if this is true or not! ahhhhhhh not trying to thread jack!
Modified by stockLS at 1:37 PM 12/18/2003
someone please tell me if this is true or not! ahhhhhhh not trying to thread jack!Modified by stockLS at 1:37 PM 12/18/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockLS »</TD></TR><TR><TD CLASS="quote">
Modified by stockLS at 1:37 PM 12/18/2003</TD></TR></TABLE>
Why second guess?? They are basically all the same, just the gear ratios are different. I wouldn't worry about it.
What could be the problem?
someone please tell me if this is true or not! ahhhhhhh not trying to thread jack!Modified by stockLS at 1:37 PM 12/18/2003</TD></TR></TABLE>
the 90-91 also have a different number of splines then then 92-93
so clutches for 90-91 wont work on 92-93 ls trannys and vice versa...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike5809 »</TD></TR><TR><TD CLASS="quote">the 90-91 also have a different number of splines then then 92-93
this is true.
But other than needing a different clutch, the '90-91 tranny's will still bolt to
a '92-'93 engine and they will still work the same and vice-versa.
Search in archived topics for katman's B engine tranny guide it will tell you ALL you need to know about ALL B engine tranny's
this is true.
well i ordered an act clutch for what i thought was my 92 ls tranny and it fits perfect so it must be a ys1. the sticker that was on it was all tore up so the y might have came off! i dont know! thanks for all the help and once again i didnt mean to thread jack!
I am in the middle of rebuilding my S1 tranny. To order bearings, I had to order from a 90-91 Acura Integra LS Special Edition. There are slight differences in bearing sizes for 90-91 and 92-93. I am relplacing all the bearings (except countershaft needle bearings) and may replace the 3rd/4th synchro set depending on how much money I have. I have posted my progress so far in the thread https://honda-tech.com/zerothread?id=588544
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridEarthquake »</TD></TR><TR><TD CLASS="quote">I have one labeled "S1" that is connected to a B18A1. You want?</TD></TR></TABLE>
Sure, I'll take it.
Sure, I'll take it.
