how does an 97 ex 5 speed engine harness differ from a 97 ex automatic engine harness??
Old Dec 14, 2003 | 10:31 PM
GOLDBERG's Avatar
Default how does an 97 ex 5 speed engine harness differ from a 97 ex automatic engine harness??
anyone know?
Old Dec 15, 2003 | 05:41 PM
vividsport's Avatar
Default Re: how does an 97 ex 5 speed engine harness differ from a 97 ex automatic engine harness?? (GOLDBER
the automatic harness has more plugs than the manual. this is a one way swap. you can put a manual where an automatic was, but not the other way around. Another way to look at it is that you can put an auto harness on a manual application. Hope that is what you were looking for.
Old Dec 15, 2003 | 08:36 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
i am using a b-series non vtec auto harness (obd1) on a five speed b-series vtec setup. no problems whatsoever. i doubt that obd2 has differences from actual wiring to the motor sensors. there will just be extra plugs and they will just hang or cut them and tape them if cleanliness matters.
Old Dec 16, 2003 | 12:43 AM
Extreme's Avatar
Difference is in the transmission side:
5 speed harness has the reverse light switch hook up that A/T don't.
A/T harness has connectors for the lockup solenoid instead.
Old Dec 16, 2003 | 03:05 PM
GOLDBERG's Avatar
i also found out that the iacv plug is a 2 wire on the 5 speed and on the auto it is a 3 wire
Old Dec 17, 2003 | 04:00 AM
EE_Chris's Avatar
Go to a junkyard and chop off a 2-wire IACV connector and wire it up.
Yel/Blk to Yel/Blk
Blk/Blu to Blk/Blu
You'll leave the orange wire alone. At the ECU, just remove the wire/pin that resides in A14 and move it over to A12. Now when you plug in a 5-speed ECU, you'll have a functioning IACV.
Old Dec 17, 2003 | 05:09 PM
GOLDBERG's Avatar
i did that but i didnt move the pinouts...engine idles fine??weirdness
Old Dec 17, 2003 | 05:33 PM
4crx4me's Avatar
You should pm katman, he knows all about what makes the A/T ecu's tick.
HTH
Skunk U
May 26, 2008 04:44 AM
1992 civic Jdm BOY
Feb 20, 2007 07:27 PM
ITR.#1446
Aug 30, 2005 06:14 PM
blackstar
Jul 6, 2005 09:50 PM
94_civicEx
Nov 15, 2004 12:20 PM
