IAT Sensor
Old Dec 13, 2003 | 09:45 AM
vultron's Avatar
Default IAT Sensor
can someone please tell me where the IAT Sensor on a B16A2 is located? i know its on the intake manifold but i still cant find it. a pic would help alot. thanks
Old Dec 13, 2003 | 10:49 AM
Redline130's Avatar
Default Re: IAT Sensor (vultron)
It's on the intake runner for the #1 cylinder. Should be on top of the runner.
Old Dec 13, 2003 | 10:54 AM
vultron's Avatar
Default Re: IAT Sensor (Redline130)
ok what does it look like??
Old Dec 13, 2003 | 01:01 PM
Ruby Civic's Avatar
plastic plug usu. white that when you take it out is kind of t shaped where the little screws hold it to the manifold...like he said ON TOP of the manifold above the #1 cylinder
Old Dec 13, 2003 | 01:38 PM
Katman's Avatar
Sorry if the image loads up slow, my friend needs to tune my webserver..
Old Dec 13, 2003 | 02:31 PM
AVATAR's Avatar
ummm I.A.T. = intake air temp = on the intake pipe
I.A.C./V. = idle air control /valve = on the intake manifold by the throttle body
Old Dec 13, 2003 | 07:48 PM
vultron's Avatar
Default Re: IAT Sensor (AVATAR)
ok i also have this proble with my swap when i hit the throtle the engine revs up and then drops back to idle while the throttle is still held down. im only throwing a code 10 (iat sensor)
would the iat not being hooked up cause this problem?
my friend said its sounds like something to do with the map sensor.
Modified by vultron at 12:39 AM 12/14/2003
Old Dec 13, 2003 | 07:53 PM
vultron's Avatar
so are you saying it should be where the cirlcle is?
Modified by vultron at 12:12 AM 12/14/2003
Old Dec 13, 2003 | 08:48 PM
Katman's Avatar
Default Re: (vultron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vultron &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, but for 96-99 civics, the IAT is a black sensor that's been relocated to the intake arm. Honda of America moved it over there for better air flow readings, i guess.
Old Dec 13, 2003 | 08:51 PM
vultron's Avatar
Default Re: (Katman)
ok whats the intake arm and can you also answer my previous question?
Old Dec 13, 2003 | 09:45 PM
chrisCNL's Avatar
if it's the 99-00 si B16A its on the intake piping. The color of the wire should be red with yellow tracer wire and black with a yellow tracer wire. It's a square plug.
EgK2o09
Dec 25, 2008 04:27 PM
graftuner34
Apr 15, 2008 05:09 PM
24rex
Aug 22, 2007 08:10 PM
BIGBLOCKEK
Oct 8, 2004 11:39 PM
89JDMcrx
Aug 7, 2003 08:31 PM
