nos and exhaust?
Old Dec 16, 2003 | 12:19 PM
GreenEX's Avatar
Default nos and exhaust?
I have two questions
1st A friend of mine has an integra and is looking to sell it. It has NOS and i wanted to buy it from him. I have a civic. Its the kind that works only at full throttle. Does anyone know how to install it and un install it b/c he want me to take it off if i want to buy it.
2nd Will a catback exhaust from 94 integra fit a 99 civic? another friend of mine wants to by his catback.
Thanks
Old Dec 16, 2003 | 03:50 PM
B16OnTop's Avatar
Default Re: nos and exhaust? (GreenEX)
the exhaust will not fit without fabrication, not sure about the kit though, try a search ive seen installation and de-installation threads before
Old Dec 19, 2003 | 05:02 AM
GreenEX's Avatar
Old Dec 19, 2003 | 08:58 AM
Devlins 91LS's Avatar
The nitrous can be swapped over, the exhaust isn't gonna fit.
Old Dec 19, 2003 | 10:17 AM
Jimmy's Avatar
Global Moderator
Default Re: nos and exhaust? (Devlins 91LS)
I'd highly suggest...<FONT COLOR="red">Searching!</FONT>
As for the exhaust you could take it to a muffler shot and get it modified to where it will still bolt up. Good luck
Old Dec 19, 2003 | 06:37 PM
GreenEX's Avatar
Default Re: nos and exhaust? (USDMDC2)
i did search. I know it can be switched. I was wondering if anyone had instructions on how to install and uninstall the nos system.
thanks
Old Dec 19, 2003 | 10:38 PM
NitrousB.I.G.'s Avatar
If you are asking how to uninstall and install a nitrous system you should not be running nitrous your gonna blow **** up. Before you are going to do this you need to a LOT of research.
Old Dec 20, 2003 | 12:10 AM
2+2=5's Avatar
Default Re: nos and exhaust? (NitrousB.I.G.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NitrousB.I.G. &raquo;</TD></TR><TR><TD CLASS="quote">If you are asking how to uninstall and install a nitrous system you should not be running nitrous your gonna blow **** up. Before you are going to do this you need to a LOT of research. </TD></TR></TABLE>
word of wisdom..understand how the it works and you'll use it wisely.
NOS stand for Network operating system in my text book
Old Dec 20, 2003 | 08:25 PM
GreenEX's Avatar
Default Re: nos and exhaust? (2+2=5)
im not going to be installing it i jsut need to take it out of my friends integra. I going to have it installed. My friend doesnt want to go throught the trouble of taking it out so i want to. I just dont know how it is ran or what needs to be undone.
Old Dec 20, 2003 | 09:05 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
what kind of "NOS" kit is it?..if u are somewhat mechanically inclined u will be able to uninstall it in about 10-20 mins...just look at it and u can see how simple it is....or maybe u can have whoever is gonna install it on your motor uninstall it on your friends?
Old Dec 21, 2003 | 05:35 AM
GreenEX's Avatar
Default Re: nos and exhaust? (bruceleeroy)
all i need to know is are there a bunch of wires that are gonna be hard for me to uninstall?
Old Dec 21, 2003 | 08:18 AM
SYD's Avatar
SYD
as far as wires there should be no more than about 4-6..depending on "what kind of kit"?..and if they have everything hooked up to a relay it will be even easier to uninstall.
Old Dec 21, 2003 | 09:22 AM
GreenEX's Avatar
ok so its not that hard to remove then.
Old Dec 21, 2003 | 01:09 PM
2+2=5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenEX &raquo;</TD></TR><TR><TD CLASS="quote">ok so its not that hard to remove then.</TD></TR></TABLE>
is not hard to remove engine for me too, so what kit is that? wet? dry?
Old Dec 21, 2003 | 01:25 PM
Kendall's Avatar
It's always easier to take something apart rather than put it together. Learn more about the ways of Nitrous before you try and play with it, and when you do, I have a wet kit for sale.
Old Dec 21, 2003 | 01:31 PM
GreenEX's Avatar
Default Re: (dc231)
Like i said im not installing it I just need to take it out. I believe its a dry kit.
Old Dec 21, 2003 | 01:33 PM
Kendall's Avatar
Just make sure that whatever hole was drilled to tap the nitrous jet into the intake gets properly plugged.
Old Dec 21, 2003 | 01:38 PM
GreenEX's Avatar
Default Re: (dc231)
I will. The only problem i have with taking it out my self is the wires. I dont know where they all are ran. I guess i can follow them and figure it out.
f22a1 ftw
Dec 17, 2009 07:30 AM
Kuchtaboy
Jan 20, 2009 07:45 AM
tnk
Jan 16, 2008 11:26 AM
hugh_jazz_sponer
Jan 27, 2004 01:23 AM
LshatchTurbo
Feb 10, 2002 08:54 PM
