Is a GSR differential same as B16 differential?
Old Dec 12, 2003 | 02:27 PM
crazy eyez killa
Guest
Posts: n/a
Default Is a GSR differential same as B16 differential?
Is a GSR differential identical B16 differential? What about the little gear for the speedo sensor?
Old Dec 12, 2003 | 04:33 PM
PupaScoopa's Avatar
Default Re: Is a GSR differential same as B16 differential? (dupalala)
Yep and Yep. I can't confirm on the bearings though. The ITR LSD inner bearing race is slightly wider than the B16 bearing.
Old Dec 12, 2003 | 06:56 PM
jdmDXrex's Avatar
Default Re: Is a GSR differential same as B16 differential? (PupaScoopa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PupaScoopa &raquo;</TD></TR><TR><TD CLASS="quote">Yep and Yep. I can't confirm on the bearings though. The ITR LSD inner bearing race is slightly wider than the B16 bearing.</TD></TR></TABLE>
actually its not.... they arent interchangeable
Old Dec 12, 2003 | 07:54 PM
Mohudsolo's Avatar
Default Re: Is a GSR differential same as B16 differential? (jdmDXrex)
Quaife lists one diff for the GSR and ITR and a different one for B16 Si and Ls Integra. I don't know what the difference is between them.
Old Dec 12, 2003 | 08:28 PM
scrambledeg's Avatar
There is a difference is size of the diff. The b16 has a smaller diff than a b18 which also means its weaker. I have seen b16's diff break numerous times at the track. But I have heard u can swap diff's? Not positve on that though.
Old Dec 12, 2003 | 10:51 PM
mmuller's Avatar
Mad Scientist
Default Re: Is a GSR differential same as B16 differential? (towcivic)
the b16/b18a/b have a smaller differential than the b18c's.if you use a itr/gsr diff. you have to use gsr/itr final drive or vise versa.
Also b16, b18a/b and newer itr's have ball bearings.Gsr and older itr's have roller bearings
mikesrex
Transmission & Drivetrain
18
Feb 7, 2014 11:32 AM
CRJenkins13
Jan 21, 2010 05:42 PM
ACTION JACTION
Apr 15, 2009 01:54 PM
C_Rock77
Apr 7, 2008 09:45 AM
