Front anti-sway bar
Old Dec 18, 2003 | 10:23 AM
Blue Si #72's Avatar
Default Front anti-sway bar
Has anyone tried installing a '96-00 Civic EX front anti-sway bar on a '00 Civic Si? I hear that the way the bar connects on the two cars is different.
To head off the questions:
Im doing this to go with the 22mm rear bar Im installing to go into STS. I hear this combo removes some of the understeer (with correct spring rates and alignment of course).
Thanks in advance,
K
Old Dec 20, 2003 | 12:46 AM
2+2=5's Avatar
Default Re: Front anti-sway bar (Blue Si #72)
What you have in the rear?
I am not too sure about getting a Meaty size front sway bar on a FWD car
some peopel even ran a big *** rear bar and disconnect the front bar for honda
Old Dec 20, 2003 | 03:53 PM
Mr. Choi's Avatar
New User
i think you can use my endlinks but jus use them upside down. check the link below.
Old Dec 20, 2003 | 07:42 PM
kommon_sense's Avatar
Default Re: Front anti-sway bar (Mr. Choi)
The ITR endlinks may also work.
Old Dec 21, 2003 | 06:47 AM
rapid_roy's Avatar
Installing a thicker front bar will promote understeer, not reduce it. And a rear swaybar isn't legal in STS. You'de be in DSP with that mod.
Cheers,
Roy
Old Dec 21, 2003 | 08:43 AM
Default Re: Front anti-sway bar (rapid_roy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rapid_roy &raquo;</TD></TR><TR><TD CLASS="quote">Installing a thicker front bar will promote understeer, not reduce it. And a rear swaybar isn't legal in STS. You'de be in DSP with that mod.
Cheers,
Roy</TD></TR></TABLE>
Actually, the rear bar is legal in STS. Also, the EX front bar is smaller then the Si one that's on the car now.
DC2 Mang
Suspension & Brakes
12
May 12, 2020 09:12 AM
RyanA
11
Jan 20, 2008 10:04 PM
SpoonKid
Oct 26, 2006 11:05 AM
Merlin8188
Sep 27, 2005 10:57 PM
Halo
22
Jan 5, 2005 05:23 PM
