"best" valves?
I've heard people say that the type-r valves are very over rated, and that aftermarket is best to go. Well I'm in need on new valves, and I'm getting CTR cams. Before I put the cams in I plan on getting a whole new valvetrain also. Would an ITR valvetrain+valves be sufficient? Will the CTR cams even make power if I bumped the redline to ~8800? 9000? I was told itr valvetrain shouldn't be reved to 9000+ so maybe I should get diff components? Suggestions? corrections? thanks!
i don't believe the ctr cams will generate enough power to 9k. most people go with aftermarket to rev that high. if you're just using the ctr's, you'll be fine with an itr valvetrain.
88fourdoor
Jun 23, 2011 05:55 AM
b18egchuy
Oct 1, 2009 09:17 PM
