Needed: Correct Toda Spec A Cam Sheet
Old Dec 13, 2003 | 05:21 PM
LeftCorner's Avatar
Default Needed: Correct Toda Spec A Cam Sheet
I bought these cams used and there wasn't a cam chart included. I've searched extensively on the Internet and can't find the numbers for the Spec A for the B16A/B18C application. Need to get them degreed before hitting the dyno. TIA
Old Dec 14, 2003 | 07:58 PM
LeftCorner's Avatar
up
Old Dec 14, 2003 | 08:44 PM
1700anddroping's Avatar
jason my man,how are things going.
Old Dec 15, 2003 | 07:18 PM
LeftCorner's Avatar
Default Re: (LeftCorner)
Hey Harvey, doin' well. Just need these specs so I can degree the cams and get my Hondata tuned, runnin' way too rich right now.
Old Dec 15, 2003 | 07:26 PM
i'm sorry man here you go.
toda a's
int lift- 11.6 mm duration-250 @ 1mm
exh lift- 11.2 mm duration-240 @ 1mm
i also have the specs for b's and c's.
hows the baby doing.
Old Dec 15, 2003 | 07:45 PM
LeftCorner's Avatar
Actually, I need the lobe centerline and at what degree the cam has max lift. Those numbers are the advertised max lift.
Kid's doin' well, almost 2 yrs. old now, growin' a little too fast. You plannin' a trip down to your Hondata tuner anytime soon?
Old Dec 15, 2003 | 08:11 PM
yeah went today.i have been having some gremlins in this h22 turbo set up that i built.after a week or may be 2 i think it was.we found it today,bad chip.he burned the map again and it worked like a charm.
275 hp 220 tq.
i built thismotor for a guy and now he cain't pay the bill,so i am going to take it out and put it in a hatch,and turn up the boost.
Rise VTEC
Oct 25, 2015 08:53 PM
Mashimaro
Dec 12, 2008 11:03 AM
Down_Und_R
May 28, 2002 04:51 PM
