D16Z6 BUILD-UP HELP?
Old Dec 14, 2003 | 02:51 AM
drevinder's Avatar
Default D16Z6 BUILD-UP HELP?
hey guy's planning on building up my z6 just wanting to know what all u guy's out there got...i all ready got semi built head from 'emerika' thank's man and i have something in mind, but just wanting to know what u guy's have done to ur's and what r some time's if an..... remember it has to be realiable because it's gonna be daily driven...oh yeah my focus is mainly on the block
thank's in advance
p.s. couldn't find anything in search
Old Dec 14, 2003 | 07:08 AM
Kendall's Avatar
Why is your focus mainly on the block? If you build a high performance engine, just doing block work will not allow you to increase power potential unless you go to higher compression pistons, or something real expensive like a stroker kit. I suggest having the head ported as well as a good valvetrain and some good cams. Even if you plan on boost, you will be able to pull good horsepower numbers with less boost if you put a lot of focus on the engines airflow.
Old Dec 14, 2003 | 08:59 AM
blackeg's Avatar
Default Re: (dc231)
i think the head might already be ported.. as for the block. i would personally look at the srp 10.5:1 compression pistons and see if you can match them to shotpeened ls rods. get new rodbolts, clutch and flywheel and you should be in buisness
Old Dec 14, 2003 | 09:35 AM
mmuller's Avatar
Mad Scientist
Default Re: (blackeg)
if you are on a budget just go higher compression.I would go like around 11.5/12 though.
If you have money to spend, then you could sleeve with bigger bore and higher compression.
Old Dec 14, 2003 | 11:25 AM
NonAutoX's Avatar
Default Re: D16Z6 BUILD-UP HELP? (drevinder)
Heres a resource you might try...
http://www.d-series.org/
Old Dec 14, 2003 | 12:00 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: D16Z6 BUILD-UP HELP? (NonAutoX)
I don't know why you posted this, Dre
Head's been built.....just no cam.
I'm telling him to go with an Exospeed cam and PR6 pistons in the Z6 block....
this should be a very reliable 11:1 setup with a good flowing head all tuned on Hondata.
Old Dec 14, 2003 | 01:26 PM
Kendall's Avatar
Default Re: D16Z6 BUILD-UP HELP? (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">I'm telling him to go with an Exospeed cam and PR6 pistons in the Z6 block....
this should be a very reliable 11:1 setup with a good flowing head all tuned on Hondata.</TD></TR></TABLE>
Agreed. I believe this setup should do fairly well and won't require anything expensive such as sleeving or forged internals. Go for it.
Old Dec 14, 2003 | 03:45 PM
drevinder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">I don't know why you posted this, Dre
because i wanted to know what other people has to say about this
Old Dec 14, 2003 | 06:09 PM
boostn420's Avatar
I agree pr6 pistons are the way to go, stock parts stock reliability.
jrod95cpe
Feb 1, 2009 11:15 AM
EGHatch94
Jan 19, 2006 11:12 AM
BoostedEgHatchFl
May 4, 2005 04:09 PM
POE
Oct 29, 2003 10:14 AM
