Test Pipe Q's
Old Dec 11, 2003 | 10:57 PM
jdmintegra1994's Avatar
Default Test Pipe Q's
I have a '94 integra LS. I currently have a 2.25" test pipe waiting to be bolted between my stock header and greddy SP exhaust system (2.36"). I just have a few questions before i put it on:
1) Do i need an O2 bung? It does not have one right now. Is it necessary to have the o2 sensor plugged into the test pipe? I will get one fabricated if i have to.
2) Will this make any 'sounds'?
3) Anything else significant that i need to know about test pipes? (besides the emissions...i'm aware of that _
Thanks in advance.
Old Dec 12, 2003 | 06:23 AM
IN VTEC's Avatar
Default Re: Test Pipe Q's (jdmintegra1994)
The OBD-1 oxygen sensors are in the collector of the exhaust manifold. There's no need to put one in the test pipe unless you need an extra one to run PCV e-vac or a wideband.
It will be louder.
Old Dec 12, 2003 | 07:03 AM
ultimatehonda's Avatar
It will only be louder and annoying in some exhaust...I think the sp will be ok
Old Dec 12, 2003 | 07:06 AM
IN VTEC's Avatar
Default Re: Test Pipe Q's (ultimatehonda)
My friend has the same exhaust and after installing the test pipe, it was definitely louder.
Old Dec 12, 2003 | 11:10 AM
iam7head's Avatar
Default Re: Test Pipe Q's (IN VTEC)
well, i think he can guess it's gonna be louder.. it's gonna give you that ricer fart can effect-raspy, high rattling sounds
I dont really think it's wise to run a test pipe on your teg(unless with boost )
in socal, 2000dollar fine if they wanna nail you.
like the guy before said, there's no need for a bung if it's obd1, if you got a obd2 equipped car, even with the bung and secondary sensor in, it will still throw a code, a soft code.
have fun tearing your eye up every stoplight
remember Hc Co Nox is your best friend now
Old Dec 12, 2003 | 10:53 PM
Default Re: Test Pipe Q's (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">well, i think he can guess it's gonna be louder.. it's gonna give you that ricer fart can effect-raspy, high rattling sounds
remember Hc Co Nox is your best friend now</TD></TR></TABLE>
I just installed it today Yes it's louder, but it's not VERY loud and it's not annoying, and rattling as you described it. What'd you mean by tearing my eye up at every stoplight?
'bout the fine stuff...i put my cat heat shields around it...so visibly it looks like a cat. For smog, i'd just replace my stock cat.
EGhatch33
May 1, 2006 09:37 PM
Ben_si
May 3, 2005 09:19 AM
fjt
Nov 17, 2004 09:40 AM
dozer1313
Sep 23, 2004 04:05 PM
blktyper2001
Oct 20, 2001 11:53 PM
