O2 sensor compatability for Air/Fuel Ration Gauge
Old Dec 15, 2003 | 01:28 PM
danmanh22's Avatar
Default O2 sensor compatability for Air/Fuel Ratio Gauge
Im going to try to make some adjustments to my VAFC settings, but I want and need to install an AF ratio gauge. Anybody have any ideas or install-instructions as to whether or not ill be able to tap the stock Honda O2 sensor for an autometer AF ratio gauge?
Modified by danmanh22 at 10:38 PM 12/15/2003
Modified by danmanh22 at 4:47 PM 12/15/2003
Old Dec 15, 2003 | 01:54 PM
AZ00lude's Avatar
Default Re: O2 sensor compatability for Air/Fuel Ratio Gauge (danmanh22)
I think you can get it from D7 and D12(ground) of the ECU connector.
I have measure this on 2000 prelude. It fluctuate between .95 and .1 volts.
Old Dec 15, 2003 | 03:38 PM
mastarolla's Avatar
Default Re: O2 sensor compatability for Air/Fuel Ratio Gauge (AZ00lude)
Keep in mind that the Autometer isnt designed for tuning in mind. I would save up and at least get the GReddy A/F monitor.
As for wiring, the only thing you need to do for an autometer is make sure that the O2 signal wire is 12v. My HX sensor runs a different voltage which makes the readings entirely incorrect (the gauge would go so lean or rich that the gauge would turn off.)
Old Dec 15, 2003 | 03:50 PM
dfoxengr's Avatar
Default Re: O2 sensor compatability for Air/Fuel Ratio Gauge (mastarolla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mastarolla &raquo;</TD></TR><TR><TD CLASS="quote">Keep in mind that the Autometer isnt designed for tuning in mind. I would save up and at least get the GReddy A/F monitor.
As for wiring, the only thing you need to do for an autometer is make sure that the O2 signal wire is 12v. My HX sensor runs a different voltage which makes the readings entirely incorrect (the gauge would go so lean or rich that the gauge would turn off.)</TD></TR></TABLE>
thats becasue you have a wideband sensor. 1v-5v
Old Dec 15, 2003 | 06:47 PM
mastarolla's Avatar
Default Re: O2 sensor compatability for Air/Fuel Ratio Gauge (hybridvteceg)
yea i know...the sensor costed me 4 bills. Damn HX!!
But still..point of the matter is that the autometer isnt very easy to tune off of.
peddyeye
Dec 1, 2008 01:52 AM
nytosc
Aug 23, 2008 07:40 AM
madman604
Oct 21, 2003 07:11 PM
blacksh
Sep 10, 2003 05:56 AM
