can someone help name this plug?
Old Dec 16, 2003 | 12:35 PM
gaydm.accord's Avatar
Default can someone help name this plug?
please name this plug
if it helps
gsr head with b20b block
ls wire harness
Old Dec 16, 2003 | 01:14 PM
IN VTEC's Avatar
Default Re: can someone help name this plug? (gaydm.accord)
My first blind stab in the dark would be VSS and then O2 sensor (altho I'm pretty sure they only come in grey sockets).
What part of the engine bay are we looking at?
Old Dec 16, 2003 | 01:54 PM
AzG35's Avatar
Default Re: can someone help name this plug? (IN VTEC)
What year car is it? It could be anything, it looks like a newer car. I have seen that plug used for IAT and the EVAP purge system.
Old Dec 16, 2003 | 02:20 PM
Aceman64's Avatar
Where is the plug? Which side of the harness is it on?
-Ace
Old Dec 16, 2003 | 03:01 PM
DVS_EF's Avatar
i think that is the vehicle speed sensor (VSS) ... you need that! or else you will throw a code, and your speedometer will not work
holla'
Old Dec 16, 2003 | 03:32 PM
976's Avatar
976
New User
Default Re: can someone help name this plug? (dvsEF)
VSS in most cases (honda) has three inputs. Do I see four? Yeah suggested, o2 or VSS...
Old Dec 16, 2003 | 03:41 PM
AzG35's Avatar
Default Re: can someone help name this plug? (976)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 976 &raquo;</TD></TR><TR><TD CLASS="quote">VSS in most cases (honda) has three inputs. Do I see four? Yeah suggested, o2 or VSS... </TD></TR></TABLE>
I only see 2
Old Dec 16, 2003 | 03:48 PM
B16OnTop's Avatar
Default Re: can someone help name this plug? (AzSi22)
its the "Im the left over plug from your swap and you dont know where the **** i go!" Plug j/k
Old Dec 16, 2003 | 05:49 PM
Foozball26's Avatar
Default Re: can someone help name this plug? (B16OnTop)
telling us the color of the witres might help dude
or do yourself a favor and get a repair manual with pin outs so you can look it up.
Old Dec 16, 2003 | 07:37 PM
slomofo's Avatar
GDD Member
Your picture sucks and that is like the most common connector on OBD1+ wiring harnesses. It looks like it's just behind the intake manifold around the place where the Purge Control solenoid goes... do you have one of those black solenoids with 2 vacuum lines going into it? One of the vacuum lines goes to the back of the intake manifold and the other goes to the charcoal canister.
If i'm wrong, then that plug looks like the kind on: O2 sensors, Reverse light, or coolant temp. Speed sensor is wider than that plug.
Old Dec 16, 2003 | 09:05 PM
XSSIVE's Avatar
Default Re: can someone help name this plug? (slomofo)
i'm with slomofo on this one, i think it may be the evap plug...what color are the wires going to the plug? here is where the evap is, check this diagram....
-Mike
Old Dec 16, 2003 | 09:16 PM
sorry guys been gone all day, its a 96 ek with 94 gsr head and 97 b20b block
it use to be an ls vtec with the oil seperator canister and the EVAP canister but the EVAP has been plugged off for now until i find a way around it and the oil seperator canister is gone because its still on the ls block(b18a) lemme go see what color the wires are and the VSS plug is already plugged in
that pic is behind the intake manifold
colors are black/yellowstripe and red/yellow stripe and is has slot for 2 pin
correct me if im wrong but the gsr does not have an EVAP solenoid?? the manifold is also gsr
and yes i do have a CEL havnt checked for codes yet was hoping to do that tomorrow
the car does run and everything on cluster works except the srs and CEL light is still on please help TIA
Modified by gaydm.accord at 6:31 AM 12/17/2003
Old Dec 16, 2003 | 09:38 PM
XSSIVE's Avatar
Default Re: (gaydm.accord)
yes the gsr has an evap...see the pics above...just checked helms again and it looks like my hunch was right that is plug c117 blk/yellow red/yellow it is the evap plug. my teg (98 GS with jdm b18c sir-g motor) has the same manifold as the gsr and i do not have an evap hooked up and the plug is just zip tied hidden behind the manifold and i throw NO codes for it. i don't think there is a need for it ...it may not be your code...check your code then let me know what it is...
-Mike
Old Dec 16, 2003 | 09:55 PM
damn ziptied on i definitely do not have the evap solenoid nor have i had it before when i had the lsvtec i guess ima need to check the CEL for codes tomorrow
Old Dec 16, 2003 | 09:59 PM
XSSIVE's Avatar
woah...no, just the plug i ment was zip tied out of the way, it is not hooked up to anything at all...and i throw no codes. sorry for the confusion. you need to check the code(s) and go from there.
-Mike
Old Dec 16, 2003 | 10:04 PM
yea 'll check the codes tomorrow, ill let you guys know how it goes
Old Dec 18, 2003 | 09:45 AM
found my codes doesnt seem to be that plug thats a good thing i got 3 codes two i've cleared just one i gotta mess with i had codes 41 7 and 3
map sensor tps and o2 sensors
the o2 sensor probably isn't in all the way or a wire got frayed or could be burnt so im going to check that out soon thanks everyone just wanted to let you guys in on that, thatsprobably whats making my car bog right know and the idle soo off
Old Dec 18, 2003 | 10:12 AM
AzG35's Avatar
Map and TPS pluts are probably on backwards/crisscrossed.
Old Dec 18, 2003 | 10:33 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
looks like the evap purge for an obd2 harness.
dohc_profile
Mar 3, 2009 05:42 AM
unclemeat8
Nov 13, 2008 05:21 PM
Blk00EJ8
12
Sep 10, 2006 08:51 AM
headhunter
15
May 31, 2006 03:38 PM
BlueShadow
Jan 16, 2005 11:04 AM
