Spoon Cams Specs
Old Dec 12, 2003 | 05:29 PM
AllMotr's Avatar
Default Spoon Cams Specs
hey i bought a set of spoon cams last year(used) and i never got the spec sheet on the cams, if any1 has these cams(street cams)with the spec sheet could u plz email me the specs it would be much appreciated. Thank You gsrboy21@hotmail.com
Old Dec 12, 2003 | 07:54 PM
Jaesung's Avatar
you should try e-mailing companies that sell the spoon cams. they can help you with that.
Old Dec 12, 2003 | 11:33 PM
99blackcivicSi's Avatar
Default Re: (Jaesung)
http://lib1.store.vip.sc5.yaho...s.jpg
that is from inlinefour email them and ask them to give you a better set i don't know if you can read those or not but i hope that helps.
Old Dec 13, 2003 | 12:36 PM
AllMotr's Avatar
Default Re: (99blackcivicSi)
thank you 99civicblacksi i will email them.
Old Dec 13, 2003 | 01:41 PM
Katman's Avatar
Default Re: (AllMotr)
check your mail..
i sent you Spoon cam specs...
Old Dec 14, 2003 | 09:07 AM
gutted's Avatar
Default Re: (Katman)
could you post up the spoon specs? just curious how they compare to other cams.
Old Dec 14, 2003 | 10:36 AM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">check your mail..
i sent you Spoon cam specs...</TD></TR></TABLE>
Also, if you don't mind, send me a copy.
Old Dec 14, 2003 | 01:02 PM
Katman's Avatar
you can download the camspec diagrams here:
http://www.jdmhondaparts.com/k...s.zip
Old Dec 14, 2003 | 01:05 PM
Kendall's Avatar
Thanks a bunch.
Old Dec 15, 2003 | 04:12 PM
AllMotr's Avatar
thank you katman that will help out lots.Merry Christmas
Old Dec 15, 2003 | 04:24 PM
Katman's Avatar
ya'll welcome..
Old Dec 19, 2003 | 08:12 AM
Darksoul's Avatar
Default Re: Spoon Cams Specs (AllMotr)
Do you have any dyno sheets with the cams and what type of valvetrain are you using? I am thinking about buying some but i need to know if it is worth it or should i just save for the JUN Type III's.
Old Dec 19, 2003 | 11:48 AM
Katman's Avatar
Default Re: Spoon Cams Specs (Darksoul)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darksoul &raquo;</TD></TR><TR><TD CLASS="quote">Do you have any dyno sheets with the cams and what type of valvetrain are you using? I am thinking about buying some but i need to know if it is worth it or should i just save for the JUN Type III's.</TD></TR></TABLE>
you'd make more power with Jun 3's.
Spoon cams are like stage 1 cams in contrast to Toda A's, Skunk2 stage 1, Jun 1's, etc.
Raising your compression ratio, when running stage 2 or higher cam profiles (if you didnt know).
dElSleepiE
May 9, 2004 11:55 AM
p-boy
Apr 25, 2002 02:35 PM
AllMotorMark
Nov 5, 2001 10:06 AM
JDM R98
Aug 2, 2001 12:26 AM
