no heat?
Old Dec 12, 2003 | 09:04 AM
11secdx's Avatar
Default no heat?
my heater blows, but does not get hot. is this going to be a thermastat problem. any info would be helpful.
Old Dec 12, 2003 | 09:29 AM
WhitEdRift's Avatar
Default Re: no heat? (11secdx)
Thermostat possibly. My gf's dad had to have the radiator flushed to fix their heater. Or perhaps it is just your heater core. Could open up the thermostat housing and see if it still works. I would try and troubleshoot before opening anything up though. Got a shop manual?
Old Dec 12, 2003 | 09:33 AM
11secdx's Avatar
Default Re: no heat? (WhitEdRift)
i do have a manual. i wondered if it was the heater core. cause the temp gauge does get up to normal operating temps.
Old Dec 12, 2003 | 09:49 AM
WhitEdRift's Avatar
So the engine does go into closed loop? Could very well be the heater core then. Should tell you have to check that in the manual. Might even have a troubleshooting section with this problem in it. The only down side is heater cores are expensive.
b0dteg
Dec 16, 2007 05:27 PM
jdadams12
Feb 12, 2007 07:03 AM
omar256hxc
19
Dec 20, 2004 12:46 PM
cr00klyn718
Oct 3, 2002 05:45 AM
takeheed
Sep 25, 2002 01:00 PM
