ls/vtec compression
Old Dec 17, 2003 | 11:56 AM
ls_vtec_crx's Avatar
Default ls/vtec compression
ok...me and a friend were arguing about what my compression would be...since the b16 pistons ar 10.2:1 and the ITR pistons are 11:1 i said that the ITR pistons would be 11:1 in a lsvtec and he said they'll drop...but i heard that the b16 pistons go up to 10.6:1 ....just wanna know what the compression will be for the b16 pistons in a lsvtec compared to the ITR pistons in a lsvtec...
Old Dec 17, 2003 | 02:26 PM
Kendall's Avatar
It depends on the B16 pistons that you use, the P30 B16 pistons will yield close to 11:1 compression, but the more common PR3 pistons will be lower than that. 10.6:1 sounds about right.
Old Dec 17, 2003 | 02:48 PM
slowazzhatch's Avatar
Default Re: (dc231)
straight from c-speed's website
b18a/b block
stock 81mm bore
b16a/b - b18c5 head
oem 3 layer head gasket
piston-to-deck height stock b16a/b
pr3 (usdm b16a pistons)
compression = 11.639915784025111
b18a/b block
stock 81mm bore
b16a/b - b18c5 head
p30 (jdm b16a pistons)
compression = 11.871967201498737
b18a/b block
stock 81mm bore
b16a/b - b18c5 head
p73-a0 (usdm b18c5 pistons)
compression = 11.085380846254102
b18a/b block
stock 81mm bore
b16a/b - b18c5 head
p73-00 (jdm b18c5 pistons)
compression = 11.627587774263281
hope this helps
Matt
Old Dec 17, 2003 | 03:01 PM
Kendall's Avatar
Oh, LS/VTEC. I'm dumb right now, just thought it was an LS.
Hondatech7713
Oct 14, 2009 05:00 AM
Pony_Fed95
Jan 18, 2006 11:10 AM
sleeperb16a
Feb 17, 2005 08:40 AM
ridestrt
Apr 24, 2003 11:22 AM
2latev8
Oct 27, 2001 11:29 PM
