What is the best block guard to use?
Old Dec 16, 2003 | 09:29 AM
95egTURBO's Avatar
Default What is the best block guard to use?
I'm about to have Eagle H-beams and 9:1 Pistons installed for a mild turbo setup in a 94' B18C1. I was just wondering which block guard to use. I don't really have the extra money to get the block sleeved.
Thanks in advance!!!!
Old Dec 16, 2003 | 10:12 AM
95egTURBO's Avatar
Default Re: What is the best block guard to use? (95egTURBO)
Anybody???
Old Dec 16, 2003 | 10:35 AM
bogus_ek's Avatar
block guards won't really do anything for you. price of sleeves are way cheaper than they used to be. save up what you'd spend on that guard, and sleeves are the way to go.
Old Dec 16, 2003 | 12:13 PM
vtecb20coupe's Avatar
B A N N E D
Default Re: What is the best block guard to use? (bogus)
i've never heard of a "bad" block guard. they all do the same thing, hold the sleeves, allow minimal flex but allow enough coolant to flow thru the block.
Old Dec 16, 2003 | 01:42 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bogus &raquo;</TD></TR><TR><TD CLASS="quote">block guards won't really do anything for you. price of sleeves are way cheaper than they used to be. save up what you'd spend on that guard, and sleeves are the way to go. </TD></TR></TABLE>
Agreed, you can get a block shipped both ways and sleeved for less than a grand. Yes it's expensive, but it's nothing compared to what it used to be.
Old Dec 16, 2003 | 06:21 PM
RyanEJ8's Avatar
Golden Eagle block guard. A friend of mine just got the Benson block, it seems that if you have the money that is the best way to go. In most peoples cases, sleeves are not necessary. The stock sleeves and a blockguard can hold ALOT of power.
Old Dec 16, 2003 | 10:43 PM
Blaze45's Avatar
Brrraaaap!
Default Re: What is the best block guard to use? (RyanCivic2000)
Make sure that if you get a blockguard that you have the cylinders honed cause supposedly it can make the sleeves form into an egg shape and screw up your sleeves/ distort them. This is what I have herd. No one has ever said anything abot it actually happening.
Blaze
Old Dec 17, 2003 | 01:13 AM
underrated's Avatar
Golden eagle or str. they both look the same.
Old Dec 17, 2003 | 12:38 PM
AllMotorMadness's Avatar
A block guard is a block guard they all work the same.
Old Dec 17, 2003 | 06:00 PM
turbod96ex's Avatar
Default Re: What is the best block guard to use? (AllMotorMadness)
ive heard that nuforms block guards are really well machined and have enough cooling holes. I ran one and didn't have any problems. The stock sleves can handle a **** load of power though, like 300+. I wouldn't worry about it.
EJ1_228
Mar 25, 2008 11:26 PM
BlangBlangTEG-93'
Mar 2, 2007 08:18 AM
BlangBlangTEG-93'
Feb 24, 2007 01:59 PM
CL SLeePeR
Apr 21, 2005 05:15 AM
SwappedTURBOegg
Nov 29, 2004 12:09 AM
