Good compression for LS/VTEC?
Old Dec 11, 2003 | 04:53 PM
Dj Lotte's Avatar
Default Good compression for LS/VTEC?
Ok I have this LS motor and I'm thinking about going LS/VTEC with it, but it has 10:1 JE Pistons in it right now. It is a sleeved B18 and bored to a 2.0, I'm just wondering what you guy would see as a reasonable set of pistons?
Also would you recommend a GSR head or B16 head? I heard the GSR raises the compression, if so how much? Should I look for a 11:1 compression JE piston? Just looking for recommendations. Gonna rip apart the block this weekend, it was given to me. A friend wanted to get rid of the motor, so I took it and now he has a B18C5 being built up. It also has a JG Edelbrock ported head, just doesn't have any valvetrain components. I figure if I do go ahead w/ the LS/VTEC to get a complete Skunk2 setup, jsut for that added insurance. Well thanks for any help that you guys offer...pz.
Old Dec 11, 2003 | 05:04 PM
Kendall's Avatar
With stock cams, 11.1:1 should be fine. I'd go with CP pistons rather than JE.
Old Dec 11, 2003 | 05:07 PM
Dj Lotte's Avatar
Default Re: (dc231)
Uhm I was looking at the Skunk2 Stage 2s =P thx for the info though ^_^
Old Dec 12, 2003 | 11:33 AM
Dj Lotte's Avatar
Default Re: (RiceFx306)
so do you think 11.5 would be pushing it?
Old Dec 12, 2003 | 12:06 PM
Kendall's Avatar
No, I'd go ahead and push it probably up to about 12:1, or just get some CTR pistons.
Old Dec 13, 2003 | 07:39 PM
Dj Lotte's Avatar
Default Re: Good compression for LS/VTEC? (RiceFx306)
12:1 ok for street on 93 octane?
Old Dec 13, 2003 | 08:35 PM
Silverbeast's Avatar
Anything is ok with the right tuning.
Old Dec 14, 2003 | 09:47 AM
mmuller's Avatar
Mad Scientist
Default Re: (HoustonSi)
well, you cant use pct's if the block is sleeved to 2.0....but yes 12.1 compression is fine
Old Dec 14, 2003 | 10:34 AM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoustonSi &raquo;</TD></TR><TR><TD CLASS="quote">Anything is ok with the right tuning.</TD></TR></TABLE>
Absolutely, and you should be okay with 12:1 compression, but I'd go ahead and get a good set of forged rods as they may be useful in a block without the piston squirters. Also have you thought about maybe using the Prelude B20A crank in the LS block? Cheap and easy way to a 2 liter and gives you the opportunity to go ahead with a set of custom rods and high compression pistons. Just a thought.
Old Dec 14, 2003 | 11:35 AM
riceboyEFsi's Avatar
If this setup is for the street this is what i would do (my boy went 12.0s all day on the bottle w/ this setup) ls block 11.5 to 1 forged je's, eagle rods b16 head skunk stage 2 s.This setup went 12.9 on motor and 12.0s on spray
Old Dec 14, 2003 | 08:25 PM
Dj Lotte's Avatar
Default Re: (dc231)
I'm not quite sure EXACTLY what's done to the motor, so I'm planning on ripping it apart this weekend, it's a B18a, it's sleeved and bored to a 2.0. It has JE 9.0 or 9.5 compression pistons. I figure it has rods of some sort in there...I just need to find out what exactly I got It also has a LS JG Edelbrock ported and polished head. At this point do you think that it would be better to just go turbo? Adding everthing up it's beginning to seem that way haha. Either way I'd need entire valvetrain components, just seems to figure to around the same price. What do you guyz think?
Old Dec 14, 2003 | 08:49 PM
Dj Lotte's Avatar
any recommendations on a good turbo kit?
Old Dec 14, 2003 | 11:47 PM
PrOjEcTpImPcIvIc's Avatar
About using either the GSR or the B16 head... i have head about more people using the B16 head because they say it's easier to convert to...
Old Dec 15, 2003 | 08:07 AM
mmuller's Avatar
Mad Scientist
Default Re: (PrOjEcTpImPcIvIc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrOjEcTpImPcIvIc &raquo;</TD></TR><TR><TD CLASS="quote">About using either the GSR or the B16 head... i have head about more people using the B16 head because they say it's easier to convert to...</TD></TR></TABLE>
Both heads are the same as far as convertion.The gsr head will yield about .2/3 higher compression than the b16, but the b16 flows 'slighty' better.
Old Dec 15, 2003 | 09:24 AM
vtecb20coupe's Avatar
B A N N E D
check with ib. i'm sure they'll recommend some good ones for you.
Old Dec 15, 2003 | 10:43 AM
Dj Lotte's Avatar
Default Re: (vtecb20coupe)
ib? haha, sorry not used to the acronymns just yet. thx for all the help though
93turbotegSAV
Nov 20, 2006 11:58 AM
EF8KiLLaBeE
Jan 21, 2006 10:37 AM
dose
Nov 28, 2002 07:14 PM
555R
Apr 10, 2002 03:57 PM
