--- novice tuner needs help in understanding fuel maps with s300 ---
i recently installed a new set of 550CC injectors and a wideband. i am street tunning through a s300. i have been running, and still am running a factory ITR program. but the car runs super rich according to the wideband.
my questions are ...
is it normal that i would run really rich just because i changed injectors? according to my wideband i need to seriously decrease fuel. i am running all motor for now.
secondly, what do the numbers in the fuel tables represent? for example in column 13 at 8900 rpm if i remember correctly it has a number = to 1170. what is that 1170?
and lastly, how do i verify my wideband is correct? the values on the gauge seems to be richer slightly than that of the s300 readings.
Re: --- novice tuner needs help in understanding fuel maps with s300 --- (tunedek)
The numbers are arbitrary numbers that represent injector pulsewidth. Some people call them 'fuel values' but in most Honda ROM editors, they don't actually mean anything specific. Larger number = more fuel, smaller = less delivered per injection event.
You need to rescale for your 550cc injectors.
Re: --- novice tuner needs help in understanding fuel maps with s300 --- (nfn15037)
I kinda thought so. Thanks for your response. Being that the number reflect pulsewidth this would make sense that while I told the S300 that I am using 550's I am still running really rich. So it sounds like I have to lean out alot of fuel. Is it possible to figure out a mathematical ratio for the differences between the old 240 and new 550's?
240/550 = .436
Multiply the whole map by .436, although there should be a function to scale the entire map int he software.
hes right there should be a space where you enter your fuel inj. size .it will get you in range
i think you are right. im ls/vtec ... not factory guts but near expected compression for a "factory" ls/vtec. im going to switch to a p30 base map and play around with that and see how it goes.
appreciate everyone's help. the idea of those number being meaningless .... well actually reflecting a value of pulsewidth makes perfect sense and really helped me understanding the fuel maps. thanks.
tunedek
08-22-2006 08:39 PM
