Engine startup
Old Aug 16, 2006 | 11:18 AM
EF-Honda91's Avatar
Default Engine startup
I have already looked this up and i have not found nothing, my problem is when ever i get into my car sometimes i turn the motor over and sometimes it does not start like its not firing, i have checked the ignition made sure the plugwires are fitted good on both ends, im fuel pump is ok, i'v primed it a whole lot of times and finally it cranks up and runs fine, other case is if the car is turned off at the gas pump i get in crank and it does not want to run it just turnes over finally sitting there 3min and crank again it turns over and finally runs? what could the problem be please help if u know.
usdm420
Aug 17, 2012 07:17 AM
KGB_JDM
Dec 15, 2009 02:12 AM
bimmeracer
Feb 11, 2008 10:19 AM
civiccoupe94
Oct 28, 2007 08:32 AM
ThinkRevolution
10
Jul 14, 2007 01:35 PM
