What are the differences between the two? What kinds of gains will I see versus the stock one? Do I need a 60 mm TB to get the most benefit? The stock first gen B16a one is a 58, all I have done otherwise is I/H/E. Thanks.
Daisy... Daisy...
The USDM ITR uses a 62 mm (throttle plate) throttle body. The JDM ITR uses an even bigger throttle body (64 mm throttle plate if i recall correctly).
I read something about different IACV's not being interchangable, would the IACV and other parts off my first gen B16a manifold work?
Daisy... Daisy...
You can check part numbers for compatability here:
http://www.acuraparts247.com
http://www.slhondaparts.com
