Weird electrical problem...main relay, no fuel pump??
Old Aug 20, 2006 | 03:11 PM
markD.'s Avatar
OMG it'Z McFLY!
Default Weird electrical problem...main relay, no fuel pump??
started out as a bad dizzy, put my friends on and still didnt start..played around with it more and started to get no response (not turning over)..tapped the starter a few times and still nothing..i removed my kill switch and it started to crank but not turn over (fuel pump is not turning on) checked all grounds, their ok..changed the main relay numerous times with new ones, didnt work..i looked down at the main relay wires and one of them is melted/fried (yellow with black stripe)..what could this be?...the fuel pump will not turn on?? any help is appreciated, thanks guys
starter is fine, dizzy is fine, main relay is fine, grounds look ok
Old Aug 20, 2006 | 04:01 PM
markD.'s Avatar
OMG it'Z McFLY!
anyone?
Old Aug 20, 2006 | 05:12 PM
markD.'s Avatar
OMG it'Z McFLY!
hmmm
Old Aug 20, 2006 | 07:48 PM
markD.'s Avatar
OMG it'Z McFLY!
helpp
Old Aug 20, 2006 | 08:47 PM
jeef84's Avatar
Default Re: (Markdmb7676)
Check ground to your pump. I had the same problem, and it turned out that I had a short to ground from the relay to the pump. Pull your wires on your pump and check voltage with the key in the on position. If you've changed relays already (which I did as well), you probably have a short or open somewhere inline.
Wiring diagrams
Old Aug 21, 2006 | 12:19 AM
fkncivic's Avatar
Default Re: (jeef84)
im not sure but i think that yellow and black wire is indeed the signal to your fuel pump, check the electrical diagram in a haynes and see. if that is indeed the wire and it is melted then it probly shorted out.
Old Aug 21, 2006 | 02:47 AM
Enzo Speed's Avatar
Default Re: (fkncivic)
Have you tried a new ECU yet?
Old Aug 21, 2006 | 03:51 PM
markD.'s Avatar
OMG it'Z McFLY!
Default Re: (Enzo Speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enzo Speed &raquo;</TD></TR><TR><TD CLASS="quote">Have you tried a new ECU yet?</TD></TR></TABLE>
yes..it was my ignition..i cleaned it out and now the fuel pump goes on..but now when i try to start it, it cranks but the fuel pump restarts?..and u hear the ecu flickering and starting over again..
Old Aug 21, 2006 | 08:33 PM
Enzo Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Markdmb7676 &raquo;</TD></TR><TR><TD CLASS="quote">
yes..it was my ignition..i cleaned it out and now the fuel pump goes on..but now when i try to start it, it cranks but the fuel pump restarts?..and u hear the ecu flickering and starting over again..</TD></TR></TABLE>
What do you mean the fuel pump "restarts"? And how does the ECU "flicker"?
Old Aug 21, 2006 | 09:11 PM
jeef84's Avatar
Can you take pics? What does the melted wire look like? Usually a melted wire anywhere is a short to ground, or a cross short. If you can, take some jumper wires and bypass the wire from your relay to the pump, if your pump works, that's your problem. But remember, you're probably seeing the results of a main problem, and not the cause. A multimeter would be your best bet here, otherwise, it's going to be guess and check with a wiring diagram.
Old Aug 21, 2006 | 09:12 PM
jeef84's Avatar
pgmfi.org
dgdarien
Jul 19, 2017 05:48 PM
EJ8CIVIC
Jul 7, 2015 03:47 AM
greyEG
May 30, 2013 07:01 PM
que6977
Sep 17, 2012 04:10 AM
markD.
10
Aug 23, 2006 06:15 PM
