Axle problem
Old Sep 14, 2006 | 08:43 AM
B16b-EJ8's Avatar
Default Axle problem
So Sunday while making an aggresive left turn i heard a bad noise my passenger side axle somehow popped out from the tranny . I didnt notice any difference in the cars driving so driving slowly to my house about 3 miles away i began to notice a significant power loss. Once i pulled into my garage hoppped out looked under the car and saw that she was bleeding badly...turned out to be tranny fluid coming from the passenger side axle hole (there was about a half inch of the splines showing). took everything apart pulled the axle out inspected it for damage everything looked fine so i popped it back in...now i have a real bad vibration while excelerating. any ideas as to why i now have vibration? Car is and EJ8 with a b16b s4c lds
Old Sep 14, 2006 | 03:34 PM
k624ash's Avatar
Default Re: Axle problem (B16b-EJ8)
trans fluid shouldnt come out just because the axle did. did you put fluid back in?
Old Sep 14, 2006 | 03:39 PM
B16b-EJ8's Avatar
Default Re: Axle problem (k624ash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k624ash &raquo;</TD></TR><TR><TD CLASS="quote">trans fluid shouldnt come out just because the axle did. did you put fluid back in?</TD></TR></TABLE>
Yeah i filled it back up...and it was def coming from the hole where the axle was. Checked the axle seal ind its fine.
Old Sep 14, 2006 | 07:49 PM
k624ash's Avatar
i dont really know for sure, but i dont think the fluid should come out when the axle is out
Old Sep 14, 2006 | 08:45 PM
qfast817's Avatar
did you check the snap ring on the end of the axle
Old Sep 15, 2006 | 08:28 AM
B16b-EJ8's Avatar
Default Re: Axle problem (qfast817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 &raquo;</TD></TR><TR><TD CLASS="quote">did you check the snap ring on the end of the axle</TD></TR></TABLE>
Yes it was a little bent when i pulled it out..i just figured it happened from the axle coming out of its hole...so i pulled it off and rounded it back out and put it back in.
KoukiMonstr
Jan 11, 2013 08:02 PM
TEGMAN89
Jan 11, 2011 05:12 AM
eklum
16
Feb 23, 2009 09:02 AM
B16b-EJ8
16
Jan 9, 2007 06:01 AM
redpeppers
May 16, 2006 11:17 PM
