How to determine the direction of rotation in an engine?
Old Sep 21, 2006 | 06:01 AM
artifex's Avatar
say it
Default How to determine the direction of rotation in an engine?
Basically, how could I determine which way the engine spins without being able to find any information on it on the interweb?
edit: or does every engine spin the same way, and it's just the trans that's different?
Old Sep 21, 2006 | 07:07 AM
so lazy's Avatar
Default Re: How to determine the direction of rotation in an engine? (artifex)
ok you've confused... me.. with what your asking...????
Old Sep 21, 2006 | 07:40 AM
thesmogman's Avatar
Default Re: How to determine the direction of rotation in an engine? (dc2-guy)
It would depend on which side of the car you are on....
If it is a stick put it in 1st gear and push forward.
If and auto I would say just bump the starter and mark the pulley.
Old Sep 21, 2006 | 07:58 AM
fuhsm1's Avatar
Default Re: How to determine the direction of rotation in an engine? (thesmogman)
If you're able to see the path that the timing belt takes, here's a way to find out. Typically, the timing belt/chain goes straight down from the camshaft gear to the crankshaft gear on either the left side or right side. If it travels down the left side, the engine rotates counterclockwise. If it travels down the right side, the engine rotates clockwise. Here's generic pics to show you what I mean:
Old Sep 21, 2006 | 09:52 AM
artifex's Avatar
say it
Default Re: How to determine the direction of rotation in an engine? (fuhsm1)
Thanks!
Old Sep 21, 2006 | 04:56 PM
Flexmyrex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by artifex &raquo;</TD></TR><TR><TD CLASS="quote">Basically, how could I determine which way the engine spins without being able to find any information on it on the interweb?
edit: or does every engine spin the same way, and it's just the trans that's different?</TD></TR></TABLE>
The SAE standard for auto engines rotation is counterclockwise viewed from the FLYWHEEL end. This is the end to which the power is applied to drive the vehicle. 90% of engines on the street rotate counterclockwise except hondas. Most Honda engines rotate CLOCKWISE (counterclockwise if viewed from the front of the engine, cylinder 1- where the accessory belts are used).
Modified by Flexmyrex at 6:16 PM 9/21/2006
Old Sep 21, 2006 | 05:54 PM
ekek888's Avatar
without starting the engine all transverse FWD engine turns the same direction as the wheels. honda only opted to mount the tranny [b, d and h] on the right side [ when ur sitted inside]. this to make room for the brakes and other items for their home market when exports was not that big.
aedude006
Sep 12, 2016 05:20 AM
peetie87
Dec 8, 2010 11:47 AM
NormS
Feb 20, 2007 12:05 PM
frank_O
Sep 29, 2005 09:37 AM
