alright ive searched please help
My crankshaft pulley bolt will not come off.
tried 3 different impact guns. tried breaker bar with 5 foot condoit pipe attached. . . i am running outa ideas on how to get this bihotch out. fuhhhh!
should i try that hexagon type thing they sell at auto parts stores?
oh yea, btw, my car is on four jackstands no axles block and head are assembled. but car is not on ground. . .
i had the same problum and i put the car back on the ground put a tortion bar on it and pined that to the ground then tried to crank it for like 2 sec's. It broke the bolt loose right away just be careful because that is a great way to snap the bolt as well, then your really screwed.
get that hex tool since you have the car on jack stands already.. it'll save you some time... but when i couldn't find my hex tool for a car i used a fu*kinq torch and aimmed it right on the bolt for about a good 10mins that bolt was red and took the impact gun and BAM it came out but this was lead into timing cover melting sometimes but i had one laying around... good luck..
arielb1
Dec 18, 2019 11:39 AM
