apexi vafc help
Old Sep 20, 2006 | 01:38 PM
fastacura99's Avatar
Default apexi vafc help
(this is a repost in hopes for a quicker and more efficient response)
I just finished installing my vafc in my 01 gsr. I'm not the best with wiring but from what I can tell everything is wired right. The 2 problems I am having tho is 1, it does not read the rpms at all and more importantly the car runs like its not on all cylinders. I know that the intro settings are right and I know I need to learn how to adjust everything. I was sure the car wouldn't run as good once I first hooked it up but I thought it would at least be driveable. So does it sound like its something else or do I just need to find somebody alot more knowledgeable on tuning it more properly. Like I said, it feels as if its not on all cylinders and has very little power. It does not seem to be driveable eventho I took it around the block to see if I could figure something out. And as for the rpm wire, my guess is it has to be something with the wiring, but is there any possibilities it could be anything else? If I dont figure something out I'll probably just disconnect it at least for now. and another possible factor is that I bought it used.
Old Sep 21, 2006 | 01:31 AM
imjustakid's Avatar
im really shure your wiring is wrong becuase your tach should read on the vafc. it's should be driveable untuned also. check the website to see if your wiring is correct: http://www.apexi-usa.com/support_installation.asp
Old Sep 21, 2006 | 07:20 AM
so lazy's Avatar
Default Re: apexi vafc help (fastacura99)
ok man... when you get that VAFC NEW.. you have to SET IT.... READ your manual... it'll tell you what to set it to for you car..
i would look at my VAFC for you but just yesterday i took the crap out and installed it into a buddy's car... so i'll try and help you out and post the settings on it..
Old Sep 21, 2006 | 11:59 AM
SpeedFreak77's Avatar
Default Re: apexi vafc help (dc2-guy)
If you haven't done so already you have to go through the initial setup procedures and then the car will run perfectly fine without having it tuned.
b18egchuy
Jan 28, 2009 08:53 AM
h22prelude99
Oct 10, 2007 12:40 AM
fastacura99
Sep 20, 2006 01:15 PM
DC2 Mang
Dec 23, 2005 08:11 AM
