Radiator Switch
Old Sep 20, 2006 | 05:24 PM
jaje's Avatar
Default Radiator Switch
I bought an older H5 Honda Civic HB for track only racing and I need to wire a radiator control switch. I'm wondering what is the best way to wire it, such as power from the master electrical shut off switch or direct from the battery (what amp fuse should I run to protect it?, etc.)
I have a 10 Amp switch so I'm hoping that will be enough.
TIA
Old Sep 20, 2006 | 08:17 PM
JimBlake's Avatar
Default Re: Radiator Switch (jaje)
I think the radiator fan switch closes the ground side of the circuit, and triggers thru a relay anyway.
Meaning... your 10 A switch would be fine, & you just wire it in place of (or in parallel with) the existing fan switch.
Old Sep 20, 2006 | 08:50 PM
jaje's Avatar
Default Re: Radiator Switch (JimBlake)
I have to get a good look at the wiring but the fan does not turn on thus maybe the wires were disconnected or the relay has gone bad. I figured I'd hook up a nice toggle switch to turn the fan on when I'm going slow through the pits, idling or in case of a red flag session I can turn it on to keep the engine cool. However, once moving it isn't needed.
Old Sep 22, 2006 | 07:14 PM
Rigginit's Avatar
One easy way to wire the switch as an independent circuit would be with a single SPST (Single pole, Single Throw) relay and Utilize your factory (or aftermarket)Thermo switch (assuming it works 100% functionally)
*12V+ (10a Fuse) to Points 87 & 86
*Point 85 to one side of Thermo switch
*Point 30 to Fan Motor V+ side
*Fan Motor ground side and 2nd thermo switch wire to Chassis Ground
Hope this helps. If not ignore it haha.
shackler
12
Jun 21, 2007 06:17 PM
NosCivic01
May 17, 2006 11:55 AM
4DRmafia
Sep 6, 2004 05:19 PM
TylerB
Jul 11, 2004 08:02 PM
shamoo
Oct 28, 2002 02:47 PM
