b18b rev limit
Old Sep 22, 2006 | 02:21 PM
DARKTEG_'s Avatar
Default b18b rev limit
what are you guys taking the revs to on the stock bottom end? and how high can i go before i spin a bearing? right now my rev limiter is set at 7400rpm
Old Sep 22, 2006 | 04:26 PM
mmuller's Avatar
Mad Scientist
Default Re: b18b rev limit (DARKTEG_)
problem is the top not the bottom....
what cams?
Old Sep 22, 2006 | 06:15 PM
DARKTEG_'s Avatar
Default Re: b18b rev limit (mmuller)
...oh, sorry... here's my setup:
b18b obd1
Act stage 4 clutch, pressure plate, and release bearing
AEM Cold air intake
AEM fuel rail
AEM tru time pulleys
B&M fuel pressure regulater, with gauge
Crower stage 1 cams
Golden eagle adjustable cam gears
GSR DC Sports 4 2 1 one piece header
GSR Cat, and DC Sports Cat back exhaust
GSR obd2 injectors
GSR transmission Phantom Grip LSD with LS 5th gear
Hondata intake gasket
Mr. Gasket distributor cap and rotor button
Nopi brand - lightweight flywheel
Performance chip tuned by crome
Prothane engine mount bushings
Skunk 2 intake manifold
Unorthadox Crank pulley
Old Sep 22, 2006 | 08:37 PM
so lazy's Avatar
hmm i wouldn't go past 7400... i wouldn't even go past 7200... on a ls... change the oil pump and you'll be safe...
Old Sep 22, 2006 | 08:46 PM
MR_FIX_IT's Avatar
change ur rod bolts too............
Old Sep 22, 2006 | 08:54 PM
so lazy's Avatar
Default Re: b18b rev limit (OldSkool_DA9)
ahh got me there brah.. lol ARP is the way to go!!
Old Sep 23, 2006 | 05:16 AM
mmuller's Avatar
Mad Scientist
Default Re: b18b rev limit (dc2-guy)
changing the rod bolts entitles pretty much for a whole rebuild.... its not just change them and go...there is machining involved wich needs the rod to be out of the engine..
I think you can go safely to 7500- 7800 on stock bolts.
Waterpump also cavitates after like 7400 rpms.
i see no aftermarket valvesprings.. i would not rev higher than like 7200-7300. you are already putting way more stress on the springs by using aftermarket cams.
Stock springs are weak for stock cams..just my opinion
Old Sep 23, 2006 | 07:18 PM
gibsanez's Avatar
rod/stroke ratio FTW!
Ignore the ls/vtec part, and read the part about r/s ratios.
http://www.phatwhippincrx.20m.com/custom4.html
Old Sep 23, 2006 | 09:32 PM
mmuller's Avatar
Mad Scientist
Default Re: b18b rev limit (gibsanez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">rod/stroke ratio FTW!
http://www.phatwhippincrx.20m.com/custom4.html</TD></TR></TABLE>
check the difference between the b18c and b18b R/S, not much of a difference to really worry about unless very high rpms.
Old Sep 23, 2006 | 10:04 PM
SPITVENOM67's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">
well the main reason you cant rev that high is 1.your head .2.b18a or b does not have the oil squirters supplying oil to the sleeves when the piston is going up and 3.no vtec girdle..so I say no more than 7400
Old Sep 24, 2006 | 07:54 AM
mmuller's Avatar
Mad Scientist
Default Re: b18b rev limit (SPITVENOM67)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPITVENOM67 &raquo;</TD></TR><TR><TD CLASS="quote">well the main reason you cant rev that high is 1.your head .2.b18a or b does not have the oil squirters supplying oil to the sleeves when the piston is going up and 3.no vtec girdle..so I say no more than 7400 </TD></TR></TABLE>
the non vtec motor has its own piston squirt lubricating system, through the rod pin hole.
Oil squirters are a neat thing, but not completely nessesary.
the girdle is pretty much only needed if you do lots of high speed highway runs.
Im in no way saying that all those things do do crap, what im saying is that for years and years now, including me, people have been revving their ls block to vtec rev limits with no problems.
rod bolts are the weak link if anything.
Old Sep 24, 2006 | 08:00 AM
so lazy's Avatar
mmuller in for the kill... ( i sure as hell rev'd the crap out of my ls block when i had it 9k everyday! )
DARKTEG_
Sep 23, 2006 09:40 AM
DARKTEG_
Sep 15, 2006 02:23 PM
DARKTEG_
Aug 24, 2006 04:17 PM
