vibration hell...
Old Sep 18, 2006 | 10:24 AM
R1020's Avatar
Default vibration hell...
i need help.
some background, before we get started:
my car: 1993 civic dx coupe
motor: 2000 B16A2 w/ S4C tranny, ITR LSD
mounts: hasport solid mounts
axles: autozone 94-97 delSol VTEC axles
okay, here's the deal:
i developed a vibration in the steering wheel back in june. it's from about 65mph and up, and varies in intensity - sometimes it's bad and sometimes it chills out for a minute.
also, not only is it transmitting vibration through the steering wheel but also through the floor/pedals.
i had my tires balanced...they were OK. when i rotated my wheels/tires to rule out a bent wheel, the vibration got even worse. my wheels had seen some serious track and street time in the past so i just decided to buy a new set of wheels (i needed new tires anyway). so i bought some 15x7 kosei K1s w/ 205/50/15 falken azenis.
first test drive: vibration is worse. i have them re-balanced at another shop, and they tell me that they were off, and they should be "perfect" now. test drive: much better, but the vibration persists....
i'm getting irritated at this point.
i got the car up in the garage and the following checked out fine:
- ball joints
- tie rod ends
- wheel bearings
i checked my axles, and noticed no tears in the boots, but my inner joint boot on the passenger side axle is leaking (badly). i repacked the boot and put a new band on, but the joint is not happy. so i figure...bingo, i have a bad inner CV joint.
i call raxles and speak with marty. really nice guy. he has a set of axles specifically for my application, so i ordered a set.
they arrive and look spectacular. i'm pumped at this point. i install them and go for a drive: not only is the 65mph+ virbration WORSE, but now i have a bad vibration on hard acceleration, in every gear. so i figure, one of the new axles is bad, or they're the wrong length for my car. OR my intermediate shaft is bad.
i had noted some bearing play in the intermediate shaft when i removed my old axles, so i ordered a new intermediate shaft and install that. no change in status.
so i remove the axles and installed the old ones. the vibration on acceleration is now gone again (as expected), and the 65mph+ vibration is back to where it was.
so, what gives? i know my passenger side inner CV joint is going bad, but what else could possibly be causing this problem??
thanks in advance for any suggestions. i'm baffled at this point. also, to note...i've been in touch with marty @ raxles about this the whole time (since i ordered my new axles), and he's stumped as well.
peter
Modified by R1020 at 8:43 AM 9/19/2006
Old Sep 18, 2006 | 10:31 AM
so lazy's Avatar
Default Re: vibration hell... (R1020)
putting the axle in right? i dunno maybe your lsd has gave up on you... lol my friend's lsd gave out on him and vibrated like hell he jumped a alittle ramp and both wheels went up and came down and bam... took the trans out and to a local trans shop, he said the lsd was busted... so i dunno whats your problem kinda hard not to see the problem..
Old Sep 18, 2006 | 11:13 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: vibration hell... (dc2-guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2-guy &raquo;</TD></TR><TR><TD CLASS="quote">putting the axle in right? i dunno maybe your lsd has gave up on you... lol my friend's lsd gave out on him and vibrated like hell he jumped a alittle ramp and both wheels went up and came down and bam... took the trans out and to a local trans shop, he said the lsd was busted... so i dunno whats your problem kinda hard not to see the problem..</TD></TR></TABLE>
How could they tell? Was the car driveable?
Old Sep 18, 2006 | 11:28 AM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: vibration hell... (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">
How could they tell? Was the car driveable?</TD></TR></TABLE>
they would most likely open the case or just do the hillbilly thing and light up the tires and see if it one wheel peels haha
also did u check the steering rack and its bushings? good luck
Old Sep 18, 2006 | 12:01 PM
so lazy's Avatar
the car drove.. they took it and put it up on the lift and put the car in gear to see if both wheels were spinning... lol jk..he took it home and i took the tranny out for him so they took it apart of course to tell us that diff was messed up.. we didnt know it was the tranny we just assume'd it was the tranny like they said NO TEAR DOWN FEE!! so **** me being asian i'm going to take it to you to tear down for FREE... haha well we had a friend that rebuilt trannys install the new diff.. now everything is fine..
maybe it is the rack..
Old Sep 18, 2006 | 12:37 PM
R1020's Avatar
yes, i'm putting the axle in right.
i'm curious about the LSD. it sure feels like it's working in the corners... i wish there was a more definitive way to test/determine if that was causing the problem.
peter
Old Sep 19, 2006 | 04:40 AM
R1020's Avatar
i forgot to include some info - not only is it transmitting vibration through the steering wheel but also through the floor/pedals.
thanks,
peter
Old Sep 19, 2006 | 06:10 AM
so lazy's Avatar
Default Re: (R1020)
jack it up on to wheels and put it in gear.. lol
denniscoles
Sep 3, 2011 07:11 PM
bboixtc
Jun 27, 2007 02:37 PM
R1020
12
Sep 19, 2006 07:00 AM
R1020
Sep 19, 2006 04:39 AM
Jer'rome
Aug 12, 2003 08:24 PM
