Real TDC or by the pointer..
Old Sep 15, 2006 | 08:29 AM
thesmogman's Avatar
Default Real TDC or by the pointer..
While I had it apart, I was checking to see why my marks on the crank pulley and the marks on the cam pulley seem to be a 1/2 a tooth off. So I pulled #1 plug and put a pencil in there and turned the crank ccw till it topped out and also looked at the position of the rotor pointing to #1. Long story short the mark on the crank pulley is about 3 degrees off from the timing pointer.
Now I know the plastic Tbelt cover can and has moved (Rubbing on the Alt belt)
But has anyone checked and verified their timing with the actual TDC. And should I time it to the corrected mark?
Thx for taking the time to read this I just wanted to explain it a little
Old Sep 15, 2006 | 12:41 PM
slomofo's Avatar
GDD Member
Default Re: Real TDC or by the pointer.. (thesmogman)
I never line up the mark on the plastic cover, use the mark on the crank gear itself or use your pencil method.
Old Sep 15, 2006 | 08:05 PM
IN VTEC's Avatar
I've verified that my ITR crank pulley and lower timing belt cover marks correspond to TDC. I used a degree wheel, pointer, and a piston stop.
You have to consider that the dwell can span several degrees of crankshaft rotation. Just because the pencil has stopped moving and the piston is at TDC, doesn't necessarily mean that the crankshaft throw is straight up and down and parallel to the cylinder bore.
fourthaxis
Jan 5, 2013 06:57 PM
94dxt
Oct 27, 2004 12:36 PM
boostedcvc
Dec 22, 2003 10:24 AM
MaxSterling
Jul 9, 2003 06:57 PM
