Master cylinder/slave ???
Old Sep 20, 2006 | 08:25 AM
repn a lude's Avatar
Default Master cylinder/slave ???
I got in my p lude in the morning and noticed there was no clutch pressure at all the pedal goes to the floor and doesnt care to come back to me haha. the trans wont go in gear when the car is ON.
Old Sep 20, 2006 | 05:50 PM
Honda Bull's Avatar
Default Re: Master cylinder/slave ??? (repn a lude)
Wow. Sounds like you got some problems... I`ve got to go to class right now. But I`ll post back.
Old Sep 20, 2006 | 06:00 PM
NathanielH's Avatar
Default Re: Master cylinder/slave ??? (Honda Bull)
are there any visible leaks from the master or slave cylinders? have someone press the pedal and then look for leaks as well. how is the fluid level?
Old Sep 20, 2006 | 07:54 PM
sorry forgot to fill in all the info hahah ya theres no leaks the fluid is at a constant level. dont make me feel all sad hahaha these arent the worst of problems haha
Old Sep 20, 2006 | 08:01 PM
BuddhaSiR's Avatar
Default Re: (repn a lude)
i would guess the master cylinder. if you have no visible leaks. Pull the rubber boot off the slave cylinder, it could just be holding the fluid in there.
Old Sep 20, 2006 | 09:07 PM
ya im replacing both im doing my lsd clutch and flywheel if thats not the problem soon enough.
92 si carbond out
went to jenny lost near 500 lbs
Old Sep 20, 2006 | 09:21 PM
Honda Bull's Avatar
1. It goes into gear when the engine isn`t running? It just won`t go in when the engine is turned on?
2. Check the clutch slave cylinder, have someone press the clutch pedal down and you can inspect what`s going on there. It`s already been said, but pulling the boot off helps as well. You can see everything easier.
Old Sep 20, 2006 | 11:09 PM
ya goes in gear off and doesnt when running im getting a slave tomm.
Old Sep 20, 2006 | 11:16 PM
so lazy's Avatar
all honda's(manual) and i believe all 5/6 speed cars go into gear when their off unless the linkage is messed up but in this case your cars linkage isn't cause obviously yours go into gear while its off... i would check that slave cylinder 1st usually it does build fluid in there... i just recently had a " 97 honda accord 5speed " come into the shop and he was having the same problem as you were... no leaks was appearing anywhere but after putting some clutch fluid in and bleed'n his clutch line man the slave cylinder was bad... this crap is only like $20 new, at a local autoparts store... this maybe your problem i'm not saying it is but its a try... good luck..
Old Sep 21, 2006 | 01:52 AM
Honda Bull's Avatar
Default Re: (dc2-guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2-guy &raquo;</TD></TR><TR><TD CLASS="quote">all honda's(manual) and i believe all 5/6 speed cars go into gear when their off unless the linkage is messed up but in this case your cars linkage isn't cause obviously yours go into gear while its off...</TD></TR></TABLE>
Well that`s what I just wanted a verification on.
Yeah. Slave cylinders aren`t too expensive if you go to a place like Advanced Auto/Autozone. Try and replace it, rebleed the system, and see what happens.
Old Sep 21, 2006 | 08:47 AM
ya cheapest goods first thanks for the input i need to go smash agian damn.
JDMswagSerf
Dec 10, 2013 09:47 PM
Duck Sauce
Apr 13, 2008 09:30 PM
O RLY
Jan 4, 2006 03:22 PM
krzyq
Mar 9, 2005 08:45 AM
97teg415
Aug 1, 2002 09:45 AM
